First vertex group not selecting properly
Open, Needs Information from UserPublic
Windows 10 x64
GTX 950M
Broken:
Date: 2019-01-18
Hash: c59370bf643f
First vertex group not selecting properly. The first vertex group seems to be selecting the opposite of the last one.
What should be selected
My vertex group
What gets selected
The selection of the last vertex group
1: Open blend and deselect everything
2: Select first vertex group and select
3: Selection should be wrong
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.Jan 21 2019, 9:56 AM
I can see your first vertex group is seemingly not what you expect (or what the screenshot suggest).
It is hard to tell why you got into that situation.
However, when I set the first vertex group again, I cannot reproduce a wrong selection anymore..., see:
(this seems to be doing the right thing, always...)
I guess we would need exact steps to reproduce the issue, something that leads to the wrong selection even though the vertex group has beeen set up differently...
Please try to find a way to reproduce this issue, marking as Incomplete for the time being...
You need a blend where you can create the vertex groups and get the same results? I found something else that might not be related ,but seems to be a issue.
1: Open the strips_3.blend.
2: Deselect everything.
3: Select and deselect "Surface_Hull".
4: Select the "Surface_Strip".
5: Delete the "Surface_Strip" vertex group.
6: Undo as far as you can.
7: "Surface_Strip" vertex group doesn't get added back and screws up following vertex groups.
