EEVEE crashes during shader compilation #60713
Closed
opened 2019-01-21 15:55:44 +01:00 by Dan · 17 comments
Operating system: Windows 7 64 bit Home edition
Graphics card: nVidia GeForce GTX 970, Driver version: 417.71
Broken: 2.80 beta, Date: 2019-01-11 00:00, Hash: f98e4cbedb, Branch: blender2.7
Editing this material while in rendered preview display mode in EEVEE will cause a crash. This occurs randomly during shader compilation and cannot be reproduced reliably.
The most effective way to cause a crash is by plugging and unplugging the output of either the multiply node or the bump node into different inputs of the principled BSDF. It may take many tries. If it still does not occur, restarting Blender may be necessary.
EEVEE Shader Compilation Crash.blend
**System Information** Operating system: Windows 7 64 bit Home edition Graphics card: nVidia GeForce GTX 970, Driver version: 417.71 **Blender Version** Broken: 2.80 beta, Date: 2019-01-11 00:00, Hash: f98e4cbedbb7, Branch: blender2.7 **Short description of error** Editing this material while in rendered preview display mode in EEVEE will cause a crash. This occurs randomly during shader compilation and cannot be reproduced reliably. **Exact steps for others to reproduce the error** The most effective way to cause a crash is by plugging and unplugging the output of either the multiply node or the bump node into different inputs of the principled BSDF. It may take many tries. If it still does not occur, restarting Blender may be necessary. [EEVEE Shader Compilation Crash.blend](https://archive.blender.org/developer/F6357207/EEVEE_Shader_Compilation_Crash.blend)
Author
Added subscriber: @DoNotCare
Member
Added subscriber: @lichtwerk
Member
Cant get it to crash here.
Is this only happening when you do this very fast?
Maybe you can show us a video (so we can try to reproduce from there)?
Cant get it to crash here. Is this only happening when you do this very fast? Maybe you can show us a video (so we can try to reproduce from there)?
Added subscriber: @MarcinTwarowski
Hi. I also have had crashes in Eevee, so I took that file and recorded a video:
https://youtu.be/FzxS6lj2KSE
Hi. I also have had crashes in Eevee, so I took that file and recorded a video: https://youtu.be/FzxS6lj2KSE
Author
The above video is basically identical to the experience I've had. Editing materials in some cases will randomly result in a crash eventually. I can't give another video for reference but I can describe how I've been getting the file provided to crash somewhat consistently: What I do is plug the color output of the multiply node into each input of the principled BSDF one by one until I reach the bottom, then do the same for the bump node. This will usually result in a crash by the time I'm finished. If not, I can usually get it to crash by restarting Blender and repeating. Of course, attempting to do any real work with materials will also crash Blender.
I should also note that this does also crash in LookDev display mode. I was not aware of this when I initially made the bug report.
The above video is basically identical to the experience I've had. Editing materials in some cases will randomly result in a crash eventually. I can't give another video for reference but I can describe how I've been getting the file provided to crash somewhat consistently: What I do is plug the color output of the multiply node into each input of the principled BSDF one by one until I reach the bottom, then do the same for the bump node. This will usually result in a crash by the time I'm finished. If not, I can usually get it to crash by restarting Blender and repeating. Of course, attempting to do any real work with materials will also crash Blender. I should also note that this does also crash in LookDev display mode. I was not aware of this when I initially made the bug report.
Added subscriber: @ZedDB
Can you guys attach the output (as a file) of blender with you run it with --debug-gpu and make it crash like this?
Can you guys attach the output (as a file) of blender with you run it with `--debug-gpu` and make it crash like this?
Here's an output from the command line. Debug mode was very sluggish so it took a while:
blender_shader_crash_debug.txt
Here's an output from the command line. Debug mode was very sluggish so it took a while: [blender_shader_crash_debug.txt](https://archive.blender.org/developer/F6433981/blender_shader_crash_debug.txt)
Clément Foucault was assigned by Sebastian Parborg 2019-01-28 17:16:39 +01:00
Author
Sorry for the delay, here is the requested file.
shadercompilationcrash.txt
I don't know if this matters, but I feel I should mention that this was done in hash: a1ae04d15a date: 2019-01-29 rather than the version in the initial report.
Sorry for the delay, here is the requested file. [shadercompilationcrash.txt](https://archive.blender.org/developer/F6454354/shadercompilationcrash.txt) I don't know if this matters, but I feel I should mention that this was done in hash: a1ae04d15a9f date: 2019-01-29 rather than the version in the initial report.
I find latest builds to be much more stable. I no longer see crashes when compiling even very complex shaders.
Clément Foucault was unassigned by Dalai Felinto 2019-12-23 16:35:19 +01:00
Added subscriber: @fclem
Added subscriber: @iss
Changed status from 'Confirmed' to: 'Needs User Info'
I have re-triaged this report and can not reproduce it.
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
I have re-triaged this report and can not reproduce it. Can you please check if this is still an issue in latest build? https://builder.blender.org/download/
Changed status from 'Needs User Info' to: 'Resolved'
Sebastian Parborg self-assigned this 2020-01-30 13:03:19 +01:00
7 days without reply, closing this as resolved then.
6 Participants
Reference: blender/blender#60713
