crashes when putting particles Along a Curve Without Curve Guide
Operating system: windows 10
Graphics card: NVIDIA GeForce GTX 1050 Ti and also happens on Intel (R) UHD Graphics 630
Broken: 2.80 beta, 91a155833e59, blender2.8, 2019-01-07
Blender crashes when putting particles Along a Curve Without Curve Guide, using the EEVEE viewport as in this tutorial linked below.
There's relatively few particles so woudn't normally happen.
Crashes when animated on the timeline 1st, 2nd or 3rd time after less 60 seconds.
Follow these steps as detailed in tutorial from youtube (also see attached file)
https://youtu.be/PYHOV3bVIG0?t=94
  1. Create a plane with particles say 500 particles.
  2. Put a force on a curve
  3. Force to be “force”
  4. In the force field panel: select Shape/curve
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.Jan 22 2019, 12:28 PM
Confirmed, checking...
--threads 1 seems to solve, so looks like race condition (will also check with ASAN)
crashes here
BVHNode *root = tree->nodes[tree->totleaf];
(where tree is NULL)
1   BLI_bvhtree_find_nearest_ex        BLI_kdopbvh.c        1388 0x2ec4ea3
2   BLI_bvhtree_find_nearest        BLI_kdopbvh.c        1431 0x2ec5066
3   closest_point_on_surface        effect.c             571  0x2a8498c
4   get_effector_data        effect.c             611  0x2a84c36
5   BKE_effectors_apply        effect.c             1050 0x2a865e0
6   basic_force_cb        particle_system.c    2072 0x2b85cc6
7   integrate_particle        particle_system.c    1363 0x2b83361
8   basic_integrate        particle_system.c    2119 0x2b86068
9   dynamics_step        particle_system.c    3641 0x2b8b520
10  system_step        particle_system.c    4082 0x2b8cb6c
11  particle_system_update        particle_system.c    4376 0x2b8de31
12  deformVerts        MOD_particlesystem.c 205  0x2546166
13  modwrap_deformVerts        modifier.c           852  0x2b259f1
14  mesh_calc_modifiers        DerivedMesh.c        1247 0x29cacb3
15  mesh_build_data        DerivedMesh.c        2044 0x29cd865
16  makeDerivedMesh        DerivedMesh.c        2156 0x29cdbeb
17  BKE_object_handle_data_update        object_update.c      207  0x2b61b02
note: to get it to crash easier, lower the number of particles to 100 in the file provided with this report.
This might be utter nonsense (or just a coincidence), but when adding a depsgraph relation to the geometry, it seems to save the corresponding BVHTree from being freed:
1
2
3diff --git a/source/blender/depsgraph/intern/builder/deg_builder_relations.cc b/source/blender/depsgraph/intern/builder/deg_builder_relations.cc
4index c8822df28e6..8014307a9f9 100644
5--- a/source/blender/depsgraph/intern/builder/deg_builder_relations.cc
6+++ b/source/blender/depsgraph/intern/builder/deg_builder_relations.cc
7@@ -401,6 +401,14 @@ void DepsgraphRelationBuilder::add_forcefield_relations(
8 DEG_NODE_TYPE_GEOMETRY);
9 add_relation(eff_key, key, "Smoke Force Domain");
10 }
11+
12+ /* add a geometry relation to keep bvhtree alive?! see T60742*/
13+ if (relation->pd->forcefield == PFIELD_FORCE) {
14+ ComponentKey eff_key(&relation->ob->id,
15+ DEG_NODE_TYPE_GEOMETRY);
16+ add_relation(eff_key, key, "Force Field");
17+ }
18+
19 if (add_absorption && (relation->pd->flag & PFIELD_VISIBILITY)) {
20 add_collision_relations(key,
21 object,
@Sergey Sharybin (sergey): mind checking on this?
