Edge Slide: redo changes result if clamping was disabled in modal #60784
2 Participants
Reference: blender/blender#60784
Operating system: Windows 10 64 bit
Graphics card: GTX 1060 6 gigabyte (The old one)
Broken: Not sure this has ever worked, I tried two versions of 2.8 as well as 2.79 and they both behave oddly, example file is a 2.8 file though.
Toggling "even" on and off in the operator panel after doing a clamped edge slide changes the result, it seems to give you the results you would have had the edge slide not been clamped at all.
In the example file, there are two vertices selected. Edge slide them in the negative Y (away from the main cube), press C to clamp, and then slide them in the positive Y so they're beyond where they started and confirm. In the operator panel, turn "even" on and back off. example.blend
Added subscriber: @Phos
Added subscriber: @lichtwerk
If you press C, you are actually turning clamp OFF (it is ON by default), this is why you can slide beyond the original extends of the rail edges.
Now for redo: this always seems to have clamp ON (need to check why this is)
Dont have to toggle
even
, changing the factor ever so slightly will also change the result as if the clamping was ON originally.Turning clamping OFF will not make this works as expected either...
Enabling and disabling even in operator panel changes resultto Edge Slide: redo changes result if clamping was disabled in modalActually this has been reported before, see #45964
Closed as duplicate of #45964
