light leaks in Cycles...? #60788
Closed
opened 2019-01-23 11:17:20 +01:00 by Andrea Coppola · 8 comments
Operating system: Windows 8.1, i7, 32 GB RAM
Graphics card: 2x GTX 770
Broken: 2.8
each release
Worked: (optional): 2.79
I know that in Eevee there is alight leak in internal environment with external lights. But I'm not sure that also in Cycles this problem is normal. The same project in Blender 2.79 and Cycles has not light leaks in the edges of the walls.01.JPG
**System Information** Operating system: Windows 8.1, i7, 32 GB RAM Graphics card: 2x GTX 770 **Blender Version** Broken: 2.8 each release Worked: (optional): 2.79 **Short description of error** I know that in Eevee there is alight leak in internal environment with external lights. But I'm not sure that also in Cycles this problem is normal. The same project in Blender 2.79 and Cycles has not light leaks in the edges of the walls.![01.JPG](https://archive.blender.org/developer/F6377723/01.JPG) ![leaks.JPG](https://archive.blender.org/developer/F6377727/leaks.JPG) **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @blenderhighschool
Added subscriber: @brecht
We need a simplified .blend file to reproduce the problem, a screenshot does not give enough information.
In general there can be raytracing precision issues, though not typically in a scene like this.
We need a simplified .blend file to reproduce the problem, a screenshot does not give enough information. In general there can be raytracing precision issues, though not typically in a scene like this.
Author
OK. This is a semplified file.
2 rooms. The first one is a joint object (removing double vertices); the second one a separate object (ceiling, wall, floor).
In the second case, you ca see the light leaks on the edges between walls, ceiling and floor.
The same scene in 2.79 has no problem.
xxx.blend
OK. This is a semplified file. 2 rooms. The first one is a joint object (removing double vertices); the second one a separate object (ceiling, wall, floor). In the second case, you ca see the light leaks on the edges between walls, ceiling and floor. The same scene in 2.79 has no problem. In attachment the *.blend file.![joint object render.JPG](https://archive.blender.org/developer/F6387340/joint_object_render.JPG) ![separated objects render.JPG](https://archive.blender.org/developer/F6387342/separated_objects_render.JPG) [xxx.blend](https://archive.blender.org/developer/F6387345/xxx.blend)
Brecht Van Lommel self-assigned this 2019-01-24 15:13:27 +01:00
The walls have a bit of displacement, not only bump mapping. You can fix that by going to Material > Settings > Displacement Method and using Bump Only.
We plan to change the default because this is confusing for users who are used to the old defaults.
The walls have a bit of displacement, not only bump mapping. You can fix that by going to Material > Settings > Displacement Method and using Bump Only. We plan to change the default because this is confusing for users who are used to the old defaults.
Author
Thanx, but why in 2.79 this was not a problem?
Because 2.79 defaults to bump mapping instead of displacement.
2 Participants
Reference: blender/blender#60788
