SSR + Reflection Plane with 0 roughness cuts off/blinks reflection at certain view angles #60803
Reference: blender/blender#60803
Operating system: Windows 10 Pro
Graphics card: Nvidia GTX 860M
Broken: 2.80,
dc3b5024be
, 2019-01-23Short description of error
When using Screen-Space Reflections and a Reflection plane at 0 roughness, Blender cuts the reflection short when the viewport/camera is looking at the reflection at certain angles.
No amount of EEVEE samples remedies this, however, if the roughness is not 0, the problem dissapears.
You can use this .blend file and rotate around the mirror or see the camera animate to affected areas.
ssr0roughnessbug.blend
Or, you can recreate the scene if you wish.
Create a plane mesh facing up to use as ground.
Create another bigger plane mesh facing horizontally to use as a mirror with a glossy shader WITH ROUGHNESS SET TO 0, then put it into a collection.
Add a reflection plane with the same size of the mirror, place it in the same spot as the mirror, set the collection visibility to "inverted" and choose the mirror's collection.
Enable Screen-Space Reflections, and rotate around the mirror. It should blink when you're rotating the camera.
Added subscriber: @Firepal
Added subscribers: @fclem, @WilliamReynish
Could not reproduce. I get no blinking here. Probably a GPU driver thing?
@fclem Any ideas?
@WilliamReynish Does it cut off/"blink" when you render ?
Yes, indeed it does.
@fclem: For me I can only reproduce then when rendering out the scene.
I have also noticed that SSR draws over the Light Path node's "Is Glossy Ray" function, which is sort of bothersome, since you can't have roughness at all without SSR.
(I was not able to replicate this in the .blend file i provided at the top, for some reason.)
https://i.gyazo.com/8ba4c5671d5deb2c5cf566f7a19dd9cc.mp4
ssr_drawing_over_isglossyray_fac.blend
This issue was referenced by
3600bb79d0
