Blender 2.80 - Subdivision surface adjust edit cage when is turned on,blender quits
Windows 8.1 Pro
Operating system:Windows 8.1 Pro
Graphics card:Geforce Gtx 960 4GB
Blender 2.80
Broken:
(example: 2.79b release)
blender crashes when option cursor to selected is used with objects,which have subdivision surface modifier
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.Jan 24 2019, 10:15 AM
Can confirm this.
Only happens when Adjust cage to modifier result is turned ON
1   mesh_create_edit_loops_points_lines         draw_cache_impl_mesh.c 4243 0x28192f1
2   DRW_mesh_batch_cache_create_requested       draw_cache_impl_mesh.c 5364 0x2820b1c
3   draw_object_backbufsel                      drawobject.c           296  0x1de4822
4   backdrawview3d                              view3d_draw_legacy.c   245  0x1db44b4
5   ED_view3d_backbuf_validate_with_select_mode view3d_draw_legacy.c   285  0x1db470b
6   ED_view3d_backbuf_validate                  view3d_draw_legacy.c   291  0x1db472f
7   unified_findnearest                         editmesh_select.c      1032 0x202a83b
8   EDBM_select_pick                            editmesh_select.c      2060 0x2032fd8
9   view3d_select_exec                          view3d_select.c        1959 0x1dd5b4c
10  view3d_select_invoke                        view3d_select.c        1994 0x1dd5dd1
I see a typo there, checking...
this error still exists - it is to do with the cage of subdivision surface
Szymon Warunek (szymi) renamed this task from Blender 2.80 - Subdivision surface causes blender to quit to Blender 2.80 - Subdivision surface adjust edit cage when is turned on,blender quits.Jan 24 2019, 4:49 PM
Szymon Warunek (szymi) updated the task description. (Show Details)
try tomorrows build (or are you building yourself?)
thank you - error has been fixed,it does not come up anymore,thanx for applying fix
