Bisect uses meters for the plane point
Operating system: Windows 10
Graphics card: nVidia 960 GX
Broken: 2.80 Beta, 7f40d553f903, 2019-01-22 01:09
(example: 2.79b release)
With units set to "Imperial" and inches, while using Bisect, the units on the plane point are in meters.
Set units to Imperial and inches. Bisect a model. To alter the plane point, inches have to be converted to meters for correct results.
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.Jan 24 2019, 3:01 PM
It uses Blender units to be precise, but yes, the unit should be the one selected in the Units panel.
Checking...
@Jacques Lucke (JacquesLucke) FYI, there are a few other operators that still use Blender Units.
For example:
  • Bevel Amount
  • Randomize Amount
Probably there are more
There are also properties that should be made aware of units still, such as:
Force Fields:
  • field.distance_min
  • field.distance_max
  • field.radial_min
  • field.radial_max
Particles:
  • root_radius
  • tip_radius
  • mass
Cloth:
  • modifiers["Cloth"].settings.mass
Softbody:
  • modifiers["Softbody"].settings.mass
Started fixing those here: D4248
@William Reynish (billreynish): Feel free to create a new task for that and assign me.
I could not not notice it haha (notifications)
@Brecht Van Lommel (brecht) Hmm grumble grumble. You are right. We are using the same property to mean a percentage and length in different cases for that one. Really I suppose we should make them two independent properties, and show the correct ones when applicable?
