Selection menu for properties does not preselect current item. #60817
5 Participants
Reference: blender/blender#60817
Operating system:
Graphics card:
Broken:
2.80,
a3261aad13
, 2019-01-042.79,
f4dc9f9d68
, 2018-03-22 (is slightly less broken than 2.80)Worked:
No item or the wrong item is selected when the selection menu of a property is opened.
Open default startup .blend.
Add "Copy Location" constraint to "Cube". (Bug is not limited to constraints.)
Set Target to "Light"
Open selection menu again for Target. "Camera" will be highlighted instead of "Light".
Possible fix
The attached diff passes the data behind
PointerRNA *ptr
as active item. This ends up in overwriting the current value ofbut->func_arg2
. I can't tell whether this will cause problems somewhere else.preselect.diff
Added subscriber: @matc
Can confirm.
Best would be if you submit you proposed fix as patch so that devs that know more about the side effects can do a code review.
Added subscriber: @ideasman42
Setting low priority since this isn't new in 2.8x.
I think the easiest way to fix this, is to use the property value as active item in ui_searchbox_update.
I previously thought that but->func_arg2 was NULL whenever the active item was not displayed correctly. But apparently it is set to block->func_arg2. And the same happens with but->func. This means there is not really a way to update func_arg2 without messing up the expected arguments for func.
This works fine with PROP_POINTER, and as before for everything else:
Added subscriber: @jenkm
Can't reproduce, has it been fixed? I tried it in 3.1.0 and 2.93.5.
Changed status from 'Confirmed' to: 'Needs Triage'
Added subscriber: @mano-wii
I reproduced this bug in the 2.80, but not the latest daily build, so it appears the bug has been fixed already.
If the problem persists, please let us know so we can re-open the report.
