Import key configuration silently fails when the filename contains a dot #60843
Reference: blender/blender#60843
Operating system: Windows 10
Graphics card: NVidia
Broken: 2.80
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
When importing a key configuration which contains a dot '.' in the filename, it acts as if it was successful, but the preset name string will be terminated prior to the dot, and the key config will not activate when selected. I would guess this is some type of search ID string error, where it is failing to locate the preset by ID because the suffix after the dot is missing, so its not matching the actual preset.
Make changes to the configuration, save as a preset containing a dot, set defaults back, then attempt to load the saved configuration.
Added subscriber: @CodeRunner
Added subscriber: @ideasman42
There was an issue displaying the name, the keymap still loaded in 2.79b and 2.8x.
Fixed the display issue:
6cc5c28d15
Could you see if the latest 2.8x works?
No version information given, marking incomplete.
Added subscriber: @brecht
Following bug tracker policy, closing report after 7 days due to insufficient information to investigate further. We can reopen the report if more information is provided.
