ctrl+Z closes the whole blender #60849
Closed
opened 2019-01-25 07:59:15 +01:00 by Bartosz Szentak · 12 comments
Operating system: win 8 Pro
Graphics card: nVidia GTX 660T
2.8 beta from 14.01.2019
I add object monkey head, apply quick smoke to it. Then hit ctrl+Z a few times trying to undo quick smoke, but instead the whole blender shuts down. Without asking to save file.
**System Information** Operating system: win 8 Pro Graphics card: nVidia GTX 660T **Blender Version** 2.8 beta from 14.01.2019 **Short description of error** I add object monkey head, apply quick smoke to it. Then hit ctrl+Z a few times trying to undo quick smoke, but instead the whole blender shuts down. Without asking to save file. **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Added subscriber: @Sundaram
This comment was removed by @Sundaram
*This comment was removed by @Sundaram*
This happens only in edit mode
Member
Member
I can't reproduce it, please be more precise in you description.
Which object has to be in edit mode?
Also: Please test the newest version of Blender and check if the problem still exists.
I can't reproduce it, please be more precise in you description. Which object has to be in edit mode? Also: Please test the newest version of Blender and check if the problem still exists.
Added subscriber: @matc
Broken
2.80, 2019-01-25, bfa8fcc542
Steps to reproduce
Open default startup .blend
With "Cube" selected switch into Editmode
Run "Quick Smoke" operator
Hit Ctrl+Z. -> Null pointer exception
Nulll pointer exception
static void mesh_undosys_step_decode(struct bContext *C, UndoStep *us_p, int UNUSED(dir))
us_p->name is "Toggle Editmode"
Additional info
Does not happen when operator (bpy.ops.object.quick_smoke()) is invoked from Python Console window.
**Broken** 2.80, 2019-01-25, bfa8fcc542bf **Steps to reproduce** Open default startup .blend With "Cube" selected switch into Editmode Run "Quick Smoke" operator Hit Ctrl+Z. -> Null pointer exception **Nulll pointer exception** static void mesh_undosys_step_decode(struct bContext *C, UndoStep *us_p, int UNUSED(dir)) us_p->name is "Toggle Editmode" **Additional info** Does not happen when operator (bpy.ops.object.quick_smoke()) is invoked from Python Console window.
I narrowed the problem down to obj.name = "Smoke Domain" (Line 375) in object_quick_effects.py.
        # add the smoke domain object
        bpy.ops.mesh.primitive_cube_add()
        obj = context.active_object
Removing the last line will make the problem disappear.
I narrowed the problem down to `obj.name = "Smoke Domain"` (Line 375) in object_quick_effects.py. ``` # add the smoke domain object bpy.ops.mesh.primitive_cube_add() obj = context.active_object obj.name = "Smoke Domain" ``` Removing the last line will make the problem disappear.
Added subscriber: @ZedDB
I can not reproduce this.
@matc can you still reproduce this with the latest beta?
I can not reproduce this. @matc can you still reproduce this with the latest beta?
I can't reproduce it. My guess is that 78719abc01f1 fixed this as well.
I can't reproduce it. My guess is that [78719abc01f1 ](https://developer.blender.org/rB78719abc01f11fee9652711ca64f83d0c777bb4f) fixed this as well.
Sebastian Parborg self-assigned this 2019-03-08 15:49:02 +01:00
Reference: blender/blender#60849
