Undoing name change on active object in edit mode causes crash.
Closed, DuplicatePublic
Broken:
2.80, fa1d5586a1ad, 2019-01-25
editmesh_undo.c can't revert name changes on active object
Open default startup .blend
With "Cube" selected, switch to edit mode
Change name of "Cube" in Outliner or Object Properties
Ctrl-Z will cause the crash.
Same crash as T60849
Crash happens in static void mesh_undosys_step_decode(struct bContext *C, UndoStep *us_p, int UNUSED(dir)) with us_p->name as "Toggle Editmode" if the name was changed in Object Properties or "Outliner selection change" for a change in Outliner.
