Node values visually reset when changed #60900
5 Participants
Reference: blender/blender#60900
Operating system: Windows 10 64 bit
Graphics card: Nvidia 1060 6gb
Broken: blender-2.80.0-git.1b6da95ccb11-windows64
Under certain circumstances, changing the value of a node snaps back to the previous value, although this is just the UI, the actual value has changed but it doesn't update in the UI. It only applies to nodes not plugged to the Material output, or to a tree that eventually plugs to the Material output
I know of two ways to trigger this bug
1: Add a material, and add a node. Make sure to not connect it to the Material Output node. Insert a keyframe on a value of the node, press play and stop the animation, and delete the keyframe of the node value. Now all the values of all the nodes (that aren't plugged to the Material output) will reset when you try to drag the sliders or type in them
2: Any new node you insert from the add menu will behave fine. Plug any of the other nodes that you know have the bug on the material output. That node will update, but the rest of the nodes will bug, including the new ones
Apart from plugging the nodes to the output or a tree connected to the output, another way of working around this is to change the name of the node in the N sidebar
You can use this blend file to play with it. The bug gets saved on the file
bugreport8.blend
Added subscriber: @moisessalvador
Added subscriber: @lichtwerk
might be related to studio/blender-studio#59495
Added subscriber: @you.le
I can reproduce this bug.
Here is another test file: keyshading.blend
I don't know how to "fix" it but I noticed that we can sliders are not reseted applying one of these patches:
1 -> commenting something in node_draw.c : p.diff
2 -> changing something in deg_eval_copy_on_write.cc :
p2.diff
Added subscriber: @brecht
since @brecht did
83f8f44791
, assigning to him...This issue was referenced by
89fa6a7a06
