Collada exporter replacing names that starts with a number with an underscore
Open, NormalPublic
Operating system: Windows 10 x64
Graphics card: GTX 660
Broken: 2.79b release
When exporting a model as a Collada file, objects and material names that start with some number get it replaced with an underscore. Maybe it also happens on other properties names.
Rename the default cube object's material name to "0Material" and export as Collada (.dae). Now reimport it back on Blender and check the material name ("_Material").
(Messed up these comments forms default to Change Status: Resolved!)
XML identifiers can't begin with numbers... although it would generally work, it's technically invalid.
I think you're on to something that if you have 0Material and 1Material and they both become _Material, then this would definitely be a bug. 0Material should become _0Material at the least so that it's sorted correctly.
Sebastian Parborg (zeddb) triaged this task as Normal priority.
This issue has already been fixed in the master branch (for Blender 2.80). I also believe that this particular issue has been there since ever. Maybe back porting the fix to 2.79 might not be too important?
