Amaranth gives lots of error
OSX 10.11.6
Intel Iris Pro
Broken: 2.80
Addon simply doesnt register due to many coding issues. Ive fixed all of them, but i also noted this on his gitHub
Not sure why this report needs to be added here??
@Rombout Versluijs (rombout) , Venomgfx stopped supporting the GitHub version of Amaranth a while ago. The only copy I know of is that is still being maintained is this version in User-Contrib.
If you have updates you want to get applied to the User-Contrib version and don't have commit access to that repo, please link a copy of the updated file to this task description (preferably as a zip file if the changes are to multiple files).
@nBurn (nBurn)
AH okay thanks, i just noticed someone else is also doing updates there. They even did updates yesterday, luckily to the parts i still need to do. I tackles some other parts like unsimplify and a lot in the color adjustment and other files.
I try and see if get this to work. I need to figure out how to get access to that repo. Im only used to working with gitHub, just a bit.
I also noticed some of those edits done are not in the new builds, is that possible? I downloaded a new build yesterday evening and than bumped into Amaranth for 2.80. Than started working on missing parts/errors for 2.80
I see update in this repo which are not in my files here
@Jacques Lucke (JacquesLucke) ,
okay thanks. I will read up on that see how that works.
thanks
Brendon Murphy (meta-androcto) closed this task as Resolved.
closing as resolved. addon has been updated. 2a0f581273e0 feel free to submit a patch if there's updates.
Yeah i had it working couple days after this submit. I wanted to make a revamp of the renderlayers and how it looked the old way. I miss that panel and find doing this in the top right more tedious than how it was. Yet i could not find info at that time how i could get the data needed from the viewlayers.
Ill see if i can have another go at it
