Function from Python not being loaded for Driver when project opened #61063
Closed
opened 2019-01-31 15:36:25 +01:00 by stephen thomas · 6 comments
Operating system: Pop!_OS (Debian) 18.10
Graphics card: GTX Titan X
Broken:
2.80 77eaa4790d
A driver calls on a python function. The python function is internal and registered.
When the project is opened, the driver can't find the function, throwing up "ERROR: Invalid Python expression".
Pressing "Update Dependencies" fixes the problem
With 'driver-bug-test.blend':
  • Open the project.
  • Enter pose mode for the armature
  • Try moving it along the X axis (Moving the armature along the x axis should make the cube move along the Y-axis, but it doesn't)
  • Exit pose mode
  • Select the cube
  • In the Drivers panel, you'll see in the Driver Property panel an error "ERROR: Invalid Python expression"
  • Clicking 'Update Dependencies' allows the driver to start working correctly.
This happens each time the project is opened.
I'd be happy to just click this button each time I load, but if you have a project with many items being driven by functions, it's not practical at all.
**System Information** Operating system: Pop!_OS (Debian) 18.10 Graphics card: GTX Titan X **Blender Version** Broken: 2.80 77eaa4790d37 Worked: (optional) A driver calls on a python function. The python function is internal and registered. When the project is opened, the driver can't find the function, throwing up "ERROR: Invalid Python expression". Pressing "Update Dependencies" fixes the problem **Exact steps for others to reproduce the error** With 'driver-bug-test.blend': - Open the project. - Enter pose mode for the armature - Try moving it along the X axis (Moving the armature along the x axis should make the cube move along the Y-axis, but it doesn't) - Exit pose mode - Select the cube - In the Drivers panel, you'll see in the Driver Property panel an error "ERROR: Invalid Python expression" - Clicking 'Update Dependencies' allows the driver to start working correctly. This happens each time the project is opened. I'd be happy to just click this button each time I load, but if you have a project with many items being driven by functions, it's not practical at all. [driver-bug-test.blend](https://archive.blender.org/developer/F6465381/driver-bug-test.blend)
Author
Added subscriber: @stephenthomas
Added subscribers: @Sergey, @brecht
@Sergey, this traces back to d192d723.
Python module registration should be done before the depsgraph like in 2.7 I think, for cases like this. Wouldn't mind an extra pair of eyes to check if it's safe though.
diff --git a/source/blender/windowmanager/intern/wm_files.c b/source/blender/windowmanager/intern/wm_files.c
index 120bf65..5295064 100644
--- a/source/blender/windowmanager/intern/wm_files.c
+++ b/source/blender/windowmanager/intern/wm_files.c
@@ -491,12 +491,6 @@ static void wm_file_read_post(
        CTX_wm_window_set(C, wm->windows.first);
-       Main *bmain = CTX_data_main(C);
-       DEG_on_visible_update(bmain, true);
-       wm_event_do_depsgraph(C);
-       ED_editors_init(C);
 #ifdef WITH_PYTHON
        if (is_startup_file) {
                /* possible python hasn't been initialized */
@@ -526,6 +520,12 @@ static void wm_file_read_post(
        UNUSED_VARS(is_startup_file, reset_app_template);
 #endif  /* WITH_PYTHON */
+       Main *bmain = CTX_data_main(C);
+       DEG_on_visible_update(bmain, true);
+       wm_event_do_depsgraph(C);
+       ED_editors_init(C);
        WM_operatortype_last_properties_clear_all();
        /* important to do before NULL'ing the context */
@Sergey, this traces back to d192d723. Python module registration should be done before the depsgraph like in 2.7 I think, for cases like this. Wouldn't mind an extra pair of eyes to check if it's safe though. ``` diff --git a/source/blender/windowmanager/intern/wm_files.c b/source/blender/windowmanager/intern/wm_files.c index 120bf65..5295064 100644 --- a/source/blender/windowmanager/intern/wm_files.c +++ b/source/blender/windowmanager/intern/wm_files.c @@ -491,12 +491,6 @@ static void wm_file_read_post( CTX_wm_window_set(C, wm->windows.first); - Main *bmain = CTX_data_main(C); - DEG_on_visible_update(bmain, true); - wm_event_do_depsgraph(C); - - ED_editors_init(C); - #ifdef WITH_PYTHON if (is_startup_file) { /* possible python hasn't been initialized */ @@ -526,6 +520,12 @@ static void wm_file_read_post( UNUSED_VARS(is_startup_file, reset_app_template); #endif /* WITH_PYTHON */ + Main *bmain = CTX_data_main(C); + DEG_on_visible_update(bmain, true); + wm_event_do_depsgraph(C); + + ED_editors_init(C); + WM_operatortype_last_properties_clear_all(); /* important to do before NULL'ing the context */ ```
Added subscriber: @ConradDueck
This issue was referenced by d31b2f8549
This issue was referenced by d31b2f854954838fb849b5b0be0011d792eecb43
Reference: blender/blender#61063
