Python API for Tools #61105
6 Participants
Reference: blender/blender#61105
Goals of this task:
Create new Tool
Every tool is a
namedtuple
calledToolDef
currently. That is a nice internal format but does not work well in an API due to the amount of attributes.There is a wrapper called
ToolDef.from_fn
that makes it easier to create new tools. This function is used can be used as a decorator. Every decorated function then turns into a tool definition.The advantage of that approach is that it makes tool definitions very compact. However, personally I think that this does not work well in an API because "why should I define a function to create a tool".
A better approach could be to use concepts that are used in other parts of the API already: classes.
Unfortunately the concept of a class does not fit exactly, because there aren't really instances of a tool. The tool would be the class itself.
A combination of the current tool syntax and classes could fit best. Below is an example of how that API might look like.
This approach also allows individual attributes to be normal values or functions (e.g. there can be a function to generate the description dynamically).
We could also change it so that
CursorTool
has to inheritToolDefinition
. However I prefer to use a decorator here because of the following reasons.__init_subclass__
as well, haven't tried it yet.namedtuple
if necessary.Since tools are (currently?) very lightweight, tools don't have to be registered. The "registration" happens when it is added to the toolbar.
Add Tool to Toolbar
I use the following terminology, not sure if other terminology is established already.
For users to be able to use a tool, it has to be in a toolbar. The goal is to allow addon developers to do the following.
We do not support creating a new toolbar. Only existing toolbars can be extended (for now).
In the current design it is difficult to allow all these operations because toolbars are mainly tuples, which means they are immutable. Changing this is not too difficult but then we face the bigger problem: How can we identify toolbars, entry blocks and entries? Also, should the identifier be just a string or some python object? I guess we will use strings, because they are used in many other areas in Blender already.
EDIT_ARMATURE
orVIEW3D.EDIT_ARMATURE
?EDIT_MESH.ADD_MESH
which contains the Add Cube and possibly other tools.EDIT_MESH.MANIPULATE.SPIN
. We might also want to flatten the namespace out a little so that entry blocks and entries themselves are in the same namespace. ThenEDIT_MESH.SPIN
would be an entry whileEDIT_MESH.ADD_MESH
is a block. Don't know how likely name collisions are.Once the identifier issue is solved, the API could look like so:
The same API could be used by Blender itself to setup the default toolbars.
The order of tools within an entry and the order of entries within a block depends entirely on the registration order and cannot be changed using the API for now. This could be added later if it proofs to be useful, however it would be better to implement support for custom reordering. Panels are handled similarly; the order of panels can be changed by the user but not by an addon (afaik).
Added subscribers: @JacquesLucke, @WilliamReynish, @ideasman42
Added subscriber: @brecht
I don't see the advantages of using a different mechanism than panels or operators, seems like another thing for Python API users to learn without a clear benefit for them.
Actually, I don't know that either. I was under the impression that this won't change for now due to the following statement from Campbell in an email:
I'm not too aware of how the internals of tools currently work, I mainly checked the existing Python code today and yesterday.
Another issue is that tools currently can't define their own properties. Again from Campbell:
Currently tools are not registered in C, so its not a given that we should make registration work like panels/operators/menus etc. internally.
If we do this it has other implications, besides registration.
If we do class registration, it could follow conventions from bpy.types.* registration.
My concern is mainly with consistency for Python API users, regardless if internally it's implemented in C or Python.
It's not clear why this needs to use a decorator instead of a subclass, and
label
instead ofbl_label
.Added subscriber: @Jayanam
Is there an official Python-API now for registering tools in Blender 2.8 / 2.9 ?
Added subscriber: @MACHIN3
Added subscriber: @ckohl_art
