Wheigt painting tools on imported models odd behavior #61146
6 Participants
Reference: blender/blender#61146
sansar_male_reference.fbx
Operating system: Windows 10 x64
Graphics card: AMD Radeon RX 580
Broken: 2.80, 2019-02-02 00:58,
4ef09cf937
Worked: None I tested
When using the wheigt painting tools on imported models the behavior is wrong/broken, if you set the skeleton into pose mode you are unable to select the mesh, to set it into wheight paint mode, preventing you from wheight painting the model or tweaking wheigts. I tried several other FBX and Collada files and all have the same problem.
Open the provided FBX and import it.
Set the armature to pose mode and try selecting the mesh in the viewport.
Added subscriber: @Anurae
Added subscriber: @lichtwerk
Think this has been reported before, but cannot find the relating report atm...
It seems to work for me when I select both objects in object mode (with the mesh being the active object). When I then switch to weight paint mode, the armature is set to pose mode.
@Anurae, can you confirm that?
Yes i can confirm that it works like this, however when you set up a mesh + skeleton inside Blender natively for example it also works fine like i described it,
another problem is you have to leave wheigt paint mode to select a different mesh object within the scene, in this case the head for example, which again works
fine if you create the items natively in Blender.
Added subscriber: @MaciejJutrzenka
plz check if this happens in 2.81
Yes still a valid problem in Blender 2.81 that might confuse Blender 2.79 users that are used to go into wheight painting mode like that.
Added subscriber: @mano-wii
Thanks for the report but that is not a bug.
See
"Lock Object Modes"
-> https://docs.blender.org/manual/en/dev/interface/window_system/topbar.html#edit-menu
