Deleting keyed field's keyframes cleverly pretends to work. #61169
7 Participants
Reference: blender/blender#61169
Debian stable.
Build from 2019-01-28 (
cad1016c20
)A secondkeyed frame, when removed, does not fully clear the keyframe.More detailed:
Keying a field (VSE -> new Color track -> Opacity field) to 1, then in a later frame keying that one to 0, then removing with Alt-I (over the field), will brown the field and remove the keyframe from the graph, but the values still change when scrubbing (and they all appear brown, between the original 1.0 keyframe and the removed keyframe).
A couple Notes:
Steps to reproduce (because, if at first you don't succeed, try over and over to make sure you can't succeed):
Alt-I to clear the field makes it brown but scrubbing shows the values changing, as if it were still keyed.
Might be related to:
https://developer.blender.org/T61148
Added subscriber: @jaggz
#61790 was marked as duplicate of this issue
Added subscriber: @snuq
Added subscriber: @WilliamReynish
I can reproduce this. Even if you remove the keyframe, as you say, it still changes over time.
Actually, the bug seems to have nothing to do with the Opacity property, but with using Alt-I. If you use Alt-I to remove keyframes, something isn't being updated correctly.
The problem seems to happen on all properties if you use Alt-I to remove keys.
Added subscriber: @iss
I was chasing something similar... Sequencer doesn't signal to depsgraph to update data and animdata are evaluated in depsgraph.
Not sure if this can be fixed temporarily, or simply we have to implement depsgraph into sequencer.
To be fair, not sure even if my conclusion of the cause is correct...
deleting curve in dope sheet editor has the same effect as alt+I.
in curve editor:
Alt-I as in Iran :)
I key over a property inserts a keyframe, Alt-I removes keys from the current frame.
Got that later :)
edited comment...
Added subscriber: @BaranYagcioglu
probably same bug with #60086
Added subscribers: @JulienDuroure, @ZedDB
Added subscriber: @brecht
Fixed by
1d5c85ffd9
