linked curves with curve modifiers arent drawn correctly #61184
6 Participants
Reference: blender/blender#61184
Operating system: Win 10
Graphics card: GTX 1080TI
Broken:
4ef09cf937
Worked: 2.79b
Whenever you have data-linked curves and both of them have curve modifiers, only the original curve will deform if you move it in object mode. Check 2,79 for correct behavior (you can have linked curves but they will deform separately). Also, if you have a modifier on a curve, blender starts to draw the original and deformed curve at the same time (which is pretty confusing).
Here's a simple .blend with the issue 1.blend
Added subscriber: @Hickz
Added subscribers: @mont29, @lichtwerk
Can confirm, @mont29: iirc you've been active with (curve) modifiers? [just reaasign if that is not for you...]
Added subscriber: @Sergey
Hrrmmm… this looks like different evaluated instances of curves sharing some data somehow (either at cache level, or something else?). Wouldn’t mind some @Sergey advice here first, in case he has some quick insight on the issue, before I dive again into curve eval process (which will take time…).
There's also a problem with curve drawing with modifiers. For example, create a curve and add a mirror modifier to it, it's not drawn in the viewport
Added subscriber: @fclem
@fclem I think that is drawing code issue in fact, adding a printf at start of
DRW_curve_batch_cache_create_requested()
, I get things like:…so looks like drawcache is shared by different objects if they use same curve obdata? At least, that function seems to take data from
ob->runtime.curve_cache
and use it to fill the VBOs ofcu->batch_cache
, if I follow it correctly.@mont29 You are right. And this is wrong.
It seems that the Object Data (Curve *)ob->data (Which is what holds the batch cache) is not duplicated as it should.
This is how Mesh are handled, (Mesh *)ob->data is NEVER shared if there is a modifier stack.
After talking with @Sergey it seems that storing the batch cache inside the object data is not a good idea. A better idea would be to store it inside the Object_Runtime struct and do some optimisation down the road to share the object runtime on similar object (i.e.: objects with the same ob->data and no modifiers).
But doing this requires some changes inside the depsgraph for tagging the object instead of the object data (notably the operation node GEOMETRY_SELECT_UPDATE). I'll propose a patch for this soon.
@Sergey After trying to go into this direction it seems really to be a can of worm situation. A lot of code it based on Eval Mesh* tagging / batch free/update.
I think the short term solution would be either:
The implication of all this makes me wonder why / what was the original design supposed to be? Having multiple ways of dealing with modified geometry seems kind of bad from my point of view.
Not sure what that means. The conversion to mesh can only happen after tessellation point of modifier stack of curve object. If you create mesh prior that you can no longer to bevel/taper, and can not apply deformation modifiers on the control points.
I am not sure why any changes to the dependency graph are needed.
To me it seems all changes are needed in
BKE_displist_make_surf()
, or maybe even incurve_calc_modifiers_post()
to convert the nurbs list to mesh after the modifier stack has been evaluated. Effectively, do the same thing as the constructive modifiers do: convert nurbs to mesh, if the mesh is not yet created after the modifiers loop is finished.Then the only exception is that you'd need to access
Object.runtime.mesh_final
as an opposite to Mesh case when you can doObject.data
. This is because we can not change object type during evaluation.This issue was referenced by
a14735d11d
This still isn't fully resolved, even though curves are now behaving correctly with mirror/array modifiers, try link copying a curve (using Alt+D) which has a curve modifier on it and you'll see what i mean. The outline is drawn correctly but the mesh data itself is not, i think it's a depsgraph thing.
@Hickz The original file does work here and did exhibit exactly what you are describing. Can you make a screenshot and/or post a new file exhibiting the issue?
@fclem
You can find one file here https://developer.blender.org/T63871 (i created a new task for a new problem, this is related i think)
The file for this particular problem is: sample2.blend
Try moving curve2 object, you'll see what i mean about the outline (it is drawn correctly, but not the mesh data)
this problem appears when you apply the modifier to curve points (this button is switched on)
@fclem
Should this be reopened, do you think? This problem is pretty huge i think (at least for my jewelry modeling workflow)
