Texture Changes don't update mesh when changed in Vertex Weight modifiers
Operating system: Xubuntu 18.04
Graphics card: Nvidia Titan X (Pascal)
Broken: 2.80 38984b10ff7b 2019-02-04
Worked: 2.79b
When using any type of texture in the Vertex Weight modifiers, an update doesn't get triggered when changing the texture used.
Looks like similar behavior to what was happening in the Displace modifier. See T58184
I've attached a setup for each modifier where you can change the texture and see it doesn't update.
Right now entering and exiting edit mode or changing a value in the modifier stack updates the mesh and takes the texture changes in to account.
  • Create mesh
  • Create and fill Vertex Group
  • Modify it with a Vertex Weight Edit, Mix or Proximity modifer
  • Use a texture for the modifications
  • Change the texture settings, mesh doesn't update
Midge Sinnaeve (mantissa) renamed this task from Texture Changes don't update mesh when changed in Vertex Wight modifiers. to Texture Changes don't update mesh when changed in Vertex Weight modifiers.Feb 4 2019, 10:39 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Checking...
