Fluid Particle settings UI elements missing / broken
Operating system: Xubuntu 18.04
Graphics card: Nvidia Titan X (Pascal)
Broken: 2.80 38984b10ff7b 2019-02-04
Worked: 2.79b
When changing the particle physics settings from Newtonian to Fluid the Forces UI elements disappear and Integration ones are missing.
Also, the Fluid Interaction box is called Relations. Maybe the wrong UI element is loaded here or has the name simply changed?
I've attached some screenshots the show the issues:
  • Create mesh
  • Add particle system
  • Change physics to Fluid
  • Forces section disappears, Integration elements remain hidden, Fluid Interaction box is either now called Relations or wrong UI element is loaded
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Feb 4 2019, 11:13 PM
This is probably my fault - I will make a patch to fix it. When I re-did the particle properties, particle fluids weren't working, so couldn't test with those settings.
