Mirroring Grease Pencil keyframes in the Dopesheet fails if the playhead is within the area being mirrored
Confirmed, NormalPublicBUG
Operating system: macOS 10.14.2
Graphics card: AMD Radeon R9 M395X 4096 MB
Broken: Blender 2.8 beta Feb 6th
Mirroring Grease Pencil keyframes in the Dopesheet fails if the current frame is within the area being mirrored
Open this blend:
You can see it's an animation of a shape moving left to right. Mirroring the keyframes should make it go right to left.
  • Place the playhead at frame 4 (or any frame inside the animation)
  • Go to Frame > Mirror > By Times Over Current Frame
  • Play back the animation
They keys are now broken
Manually scaling the keyframes by negative 1 works normally and gives correct results.
Related Objects
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Feb 6 2019, 3:43 PM
@William Reynish (billreynish) I can't seem to reproduce this on my end. If I follow your steps (and select all keyframes), they seem to mirror just fine for me.
I just need to move them into the frame range again after mirroring as some are mirrored outside. But the same thing happens if I simply scale with -1.
@Sebastian Parborg (zeddb) Did you place the playhead inside the tange of the keyframes? Eg on frame 4, for example? And did you press play to varify that it plays backwards properly?
Yes (?):
My mistake, uploaded wrong file. Here's a simple shape moving left to right, which shows the problem better:
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 50.
I can reproduce now with the updated .blend file.
@Antonio Vazquez (antoniov) feel free to reassign if this is not for you.
Sybren A. Stüvel (sybren) changed the subtype of this task from "Report" to "Bug".Jan 9 2020, 5:03 PM
