Import OBJ error #61254
6 Participants
Reference: blender/blender#61254
Operating system:
Windows 7 Ultimate Service Pack 1
Graphics card:
Nvidia Quadro K5100M
Broken:
(example: 2.79b release)
(example: 2.80,
8c87af7440
, blender2.8, 2019-02-06, as found on the splash screen)Worked: (optional)
Importing in the following files give an error in blender 2.8
Choose File Import Wavefront (.obj) choose the files called Tire_Original_Test_LW2018.obj it imports in fine
Choose File Import Wavefront (.obj) choose the files called Tire_Original_Test_LW2019.obj it gives the following error
Choose File Import Wavefront (.obj) choose the files called Tire_Original_Test_LW2019.01.obj it gives the following error
If you try and import any of the .obj files below in previous versions of blender they all work
Hope this helps
Thanks,
Jason
Tire_Original_Test_LW2019.0.mtl
Tire_Original_Test_LW2018.mtl
Tire_Original_Test_LW2019.mtl
Tire_Original_Test_LW2019.0.obj
Added subscriber: @jsboudreau
UPDATE: I noticed that the Tire_Original_Test_LW2018.obj had the UV mapped stripped from the file which allows it to import into blender 2.8
but the other two models below still have the UV maps in the model and these will not import into blender 2.8
So from the looks of it. It looks like it's an issue with UV maps in the model.
Hope this helps
Thanks,.
Jason
Added subscriber: @Josephbburg
I the same issue with a model exported from Maya. It has UV's (that are an utterly awful mess), imports just fine in 2.79 (with the awful UV map) but fails in 2.8.test_import.obj
Added subscriber: @MaciejJutrzenka
i also have prolbem with importing 800mb tank object. it works fine 2.79... and also it works if i link object from 2.79... however it dosn't want to import in 2.8.. but it works fine in 2.79 tested build from 02/06/2019
Added subscribers: @mont29, @lichtwerk
These are caused by one of the parsing performance improvement commits on
Nov 20
.@mont29: I think you're much faster nailing this?
This issue was referenced by blender/blender-addons@9c7fb7e2ca
Hi, There is still an issue with importing in .obj files that have pure black in the color channel.
If you try and load in a .obj that has any surface with pure black Red=0 Green=0 Blue=0 on the model you will get this error message
This model below has it's surfaces set to R=0 G=0 B=0 ( it will not import into blender latest version Feb 21 2019
Tire_Original_Pure_Black_Color_Channel_R0_G0_B0.mtl
Tire_Original_Pure_Black_Color_Channel_R0_G0_B0.obj
This model below has it's surfaces set to R=0 G=0 B=1 (it will import into blenders laters version Feb 21 2019
Tire_Original_Not_Pure_Black_Color_Channel_R0_G0_B1.mtl
Tire_Original_Not_Pure_Black_Color_Channel_R0_G0_B1.obj
Hope this helps get to the bottom of the bug
This same bug above is in the latest stable version of blender 2.79
Thanks,
Jason
@jsboudreau please make a new report
