Vertex Transformation, Number Rounding Problem, versions 2.79 and above! #61298
7 Participants
Reference: blender/blender#61298
Operating system: Windows 7 x64 Ultimate SP1
Graphics card: onboard Intel HD 4600
Broken:
2.79 (latest) AND 2.80 latest beta
2.77a works correctly!
This problem is happening on blender versions 2.79 and 2.80! It is NOT present in 2.77a.
How to replicate: Selecting a vertex and clicking on its axis transformation on the right pane (N), for example on the Y-axis, enter the number 47.15426 for example.
So far, so good. But after clicking on that same field again (to edit or just copy the value to the clipboard), it gets automatically rounded off (just by clicking on it) to 47.1543 for no reason.
Basically, when I want to select the coordinate of that vertex (47.15426 is its correct value) and just copy it to my clipboard so I can paste it into another program, that number gets changed automatically to 47.1543 inside Blender and it stays that way after de-selecting the Y-axis number field in the Transformation tab!
In 2.77a version, no such thing can happen, I have been using it since 2016 and there weren't any problems with that.
I have tested both the 32-bit and 64-bit versions of the affected 2.79 and 2.80 releases, all have this issue.
Open the attached .blend file: vertex_coordinate_rounding_problem.blend
The vertex is already selected. Just navigate with your mouse to the Y: axis transformation and click on the field with the number. It will change from 47.15426 to 47.1543 (which literally lowers the precision of the float by a decimal point). If you try that in Blender 2.77a, this will not happen.
Added subscriber: @trashcontainer
This issue was referenced by blender/blender-staging@dc6fcb8ecf
Added subscriber: @DragMZ
The reason for this is: UI/floats: Reduce our UI_PRECISION_FLOAT_MAX by one to avoid most rounding issues. used in interface_handlers.c:3052:
Added subscribers: @mont29, @ZedDB
@mont29 is there anything to do here as this seems to be a intended change?
What was the reasoning for this? Version 2.77 didn't do that, what prompted the change?
Me, personally, I'd be thrilled to have an option to turn that feature off, I don't want it to round off things on its own.
Maybe put it as an option (toggleable on/off) for people who want to round off their vertex coordinates by X amount of decimals?
Issue is due to bug in code generating string for edited numeric button. Tried a quick fix, but there are actually more issues in our handling of float precision in UI code, so will check further to properly unify/fix the whole mess.
Edit: Any ETA on a fix for this?
Any news on whether this has been fixed?
Added subscriber: @iss
Changed status from 'Confirmed' to: 'Needs User Info'
I have re-triaged this report and can not reproduce it.
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
@iss Just tested on 2.81.16
For testing, I used the OP posted value of X: 47.15426 for a vertex on a starting box.
Here is what happens - the value is now correctly written in the coordinate field menu (N), but it rounds up to 47.1543 when you select the value in the Transform Vertex menu.
What needs to change (in my opinion) is that this rounding up is not needed (there is simply no reason for a value to change just because you selected the numbers in the N vertex transform menu).
After the value changes, if you hit ESC, it will revert back to the correct 47.15426. But if you de-select the field with the auto-changed value (when you select it, it goes from 47.15426 to 47.1543) then it will remain 47.1543, which essentialy moves your vertex for no apparent reason. This became an issue since blender 2.78 up to this day with the newest versions. Last known version that doesn't have this is 2.77a
Hope you guys can make it so that this auto-switching with values just stops happening, thanks for your hard work!
P.S this happens in 2.82 Alpha too
Added subscriber: @Harley
Isn’t 6 digits of precision exactly what is expected from our floats? Put in a number with 6 digits of precision or less and get the exact number out. Try using more precision and you will lose some.
@Harley the issue is not with the 6-digits of precision, it's with the interface code that "rounds up" just because you selected that field (you manually input something, hit enter - its correct, but if you then select the same field you did the manual input to, it rounds up and you have to hit ESC or else the vertex will move to the rounded up value)
Hi guys, any chance this gets patched in for the 2.83 final release? Thanks, hope it's not too much work to get that resolved
