Operating system: Linux Mint 19.1
Graphics card: GeForce GTX 960 (GPU 0)
Broken: 2.80
Worked: 2.79b
At the moment of export I need to set the "Scale" value to 1000.0 in order to get the proportions properly.
- Create a .blend file with a mesh with correct measurements.
- Select File > Export > Stl (.stl)
- Export normally and try to see the model on another application that uses .stl files, like Repetier Host
