Error while enabling node rangler addon
Operating system: Win 10 home 64bit
Graphics card: Nvidia Geforce Gtx 970m
Broken: 2.79b release / 2.79a release
When i try to enable Node Wrangler addon an error occurs:
Report: Error
File"A\Blender\Blender-2.79a-windows64\2.79\scripts\modules\addon_utils.py", line 331, in enable
mod =_import_(module_name)
File"C:\Users\...\AppData\Roaming\Blender Foundation\Blender\2.79\scipts\addons\node_wrangler.py", line 1001
base_color: StringProperty(
SyntaxError: invalid syntax
  1. Open Blender
  2. User Preferences
  3. Add-ons
  4. Try to enable node wrangler
I know Node Wrangler works in 2.8 (beta) BUT i'm learning with add-ons only aviable in 2.79. In 2.8 other add-ons i use doesn't work
Jacques Lucke (JacquesLucke) triaged this task as Needs Information from User priority.Fri, Feb 8, 5:21 PM
Where did you get your Blender build?
For some reason a Blender 2.8 version of Node Wrangler is in you 2.79 addons path.
Do you have an idea why?
I've downloaded all my builds from blender foundation site. I've downloaded lates version of node wrangler from github.
I've played with different variations by updating manually (overwriting it in addon folder). My last try was: i took node_wrangler_py from addon folder of 2.8 Blender and copied it to addon folder of 2.79 Blender. BUT I need to stress thist out that the error existed before I've tried 2.8 version of blender.
I've reinstalled Blender 2.79 (mainly overwrited whole addons folder with the original). The error of two existing node-wrangler.py files appeared (one in program folder, second in Roaming folder). Deleted the latter and it worked like a charm.
Thank you for pointing out my mess with the files :)
case closed
cheers
