Normal Map default values are wrong
Operating system: Ubuntu 18.10
Graphics card: GeForce GTX 1060 6GB
Broken: 2.80beta, 690478027bd7
If you make a new Normal Map node, the "Strength" parameter defaults to 1.0
If you right click and choose "reset to default value" it goes to 0.0
A similar problem occurs with the color: default is RGBA .5,.5,1,1 but resetting it to default goes to 0,0,0,0
Brecht Van Lommel (brecht) closed this task as Archived.
The "Reset to Default Value" feature unfortunately has this problem with many properties. We do not consider it a bug currently, but a known limitation that will require a bigger effort to fix throughout Blender.
