Edge Split does not Preserve sharp corners
Closed, InvalidPublic
Windows 10 Pro
Operating system:Windows 10 Pro 64 bit
Graphics card:
Blender 2.80
Broken:
(example: 2.79b release)
Worked: it did not work in both versions - Blender 2.79b had exactly the same problem
**corners of polygon object are open,when i used edge split and subdivision surface{F6562212}
should i apply something to the object?
We do not handle user support on this tracker, only bug reports. User forums like blenderartists.org or blender.stackexchange.com should be used for that matter.
this is perfectly normal and expected behavior, please read the docs… If you slip geometry, there is no way afterwards that subdiv would know how to keep *some* split, border edges unsmoothed.
ok - thank you for explanation
