Fluid simulation ignoring Time Start and End
Closed, InvalidPublic
Operating system: Win 10
Graphics card: gtx 970
Broken: 2.8 Latest build
Fluid simulation aways starts at 0 seconds and aways end in the last frame, does not matter if you change the values under domain settings.
1- create a fluid simulation with inflow(tested here with inflow)
2- change start frame and end frame to something different from start and end frame from the scene itself.
3- Bake it
Sebastian Parborg (zeddb) closed this task as Invalid.
Sebastian Parborg (zeddb) claimed this task.
The start and end time is not used to set when the simulation should start in the timeline.
It is used to determine when the baked data should be saved and the time scale:
https://docs.blender.org/manual/en/latest/physics/fluid/types/domain.html
So for example with a start time of 10 seconds, the fluid sim will simulate 10 seconds before it save the results. Then it will map the start and end of the simulation to the available frames in the timeline.
