Crash with smoke #61399
5 Participants
Reference: blender/blender#61399
Operating system: Windows 10
Graphics card: Nvidia 1070 GTX
Broken: blender-2.80.0-git.191b8951f7af-windows64
Moving to the next frame on the timeline causes blender to crash.
I open smoke.blend (which has a baked smoke sim on my machine), Z -> rendered, then move to the timeline and Right arrow. Boom.
This is my first bug submission on this project, let me know if I should provide other information, etc. Thanks!
Added subscriber: @chbug
Forgot the full system info if needed.
system-info.txt
Added subscriber: @lichtwerk
Cannot reproduce here.
First I thought it was a duplicate of #58471 (but now I cannot reproduce that other report either anymore...)
I can't reproduce it either..
@chbug, can you reproduce this issue in new files as well?
Maybe also try a newer Blender version.
If you have access to another computer, you can also try it there to see if this problem is specific to your computer.
I'll try to reproduce with an even more recent build than 0208, which is the version I also used to create the sample file. Also I'll try to discard the cache and bake again. If it turns out it's related to the baked data, is there a simple way to share the 30GB of cached data, or is it even worth it?
I can still reproduce it with Blender 2.80 rel. 2019/02/13. I can also reproduce it by discarding the baked files and regenerating them. When you attempted to reproduce, did you bake the smoke sim?
I can try to start with a fresh file, but given that baking takes 20 minutes, I might get lucky but if I need to fiddle with lots of parameters it might take a long time to set things up the same way. Given that the failing file was generated with rel. 2019/02/08, is there a solid reason to expect it to be any different anyways?
Alternatively, if you have pointers on how to extract a stack trace of the crash on a windows machine, I can try to do that. I'm more familiar with development on linux systems, but my beefier machine runs Windows.
Added subscriber: @ZedDB
Does it not crash if you download this dll and copy it so its located in the same directory as 'blender.exe' and run Blender normally?
Same crash with the DLL (and blender being super slow before that, which was expected I guess).
Yes, that .dll forces blender to use software rendering. So now we know that this isn't an issue with your GPU drivers at least.
I can't reproduce this even if I bake the simulation, yes. It doesn't seem to crash when I move around the timeline in rendered mode.
Because it seems like none of the devs can reproduce this, can you see if you can reproduce this issue from scratch with a build from today?
Reproduced from scratch from today's build (see untitled.blend). You need to bake the sim, switch to rendered mode, and use Shift-Left & Shift-Right to jump in the timeline (with this file it wasn't enough to Shift-Right).
Also, I installed the dev environment and can provide full stack traces if it helps.
Also cannot reproduce here...
@chbug: did you have success getting a full stack trace?
Added subscriber: @mont29
