You can't register a `GizmoGroup` after unregistering it
Open, Confirmed, MediumPublic
Operating system: windows 64bits
Broken:
blender2.8, 2019-02-10
When trying to unregister and then register an addon that supports GizmoGroups. An error message is displayed and the process stops.
In the gizmo_simple.py template, add these lines:
issubclass(MyLightWidgetGroup, bpy.types.GizmoGroup)
bpy.utils.unregister_class(MyLightWidgetGroup)
bpy.utils.register_class(MyLightWidgetGroup)
When trying to execute the code through Blender, you should see the error message :
  File "\gizmo_simple.py", line 52, in <module>
TypeError: expected GizmoGroup subclass of class "MyLightWidgetGroup"
Error: Python script fail, look in the console for now...
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.Feb 11 2019, 11:52 AM
It's interesting that this error is related to issubclass(MyLightWidgetGroup, bpy.types.GizmoGroup). When I remove this line, it works just fine.
Here is a solution I did to avoid this error.
But it looks kind of hachy.
diff --git a/release/scripts/modules/bpy_types.py b/release/scripts/modules/bpy_types.py
index 32e8fe40c6a..f105c2980f8 100644
--- a/release/scripts/modules/bpy_types.py
+++ b/release/scripts/modules/bpy_types.py
@@ -646,6 +646,12 @@ class Gizmo(StructRNA):
         return (batch, shader)
+# Dummy class to keep the reference in `bpy_types_dict` and avoid
+# erros like: "TypeError: expected GizmoGroup subclass of class ..."
+class GizmoGroup(StructRNA):
+    __slots__ = ()
 # Only defined so operators members can be used by accessing self.order
 # with doc generation 'self.properties.bl_rna.properties' can fail
 class Operator(StructRNA, metaclass=RNAMeta):
(It would be nice if it could be fixed soon)
