Out of Cuda memory
Operating system: OSX 10.13.6
Graphics card: GTX 1070Ti and GTX 1070
Broken:
blender-2.80.0-git20190211.b8d4f06b102d-x86_64
Pablo mentioned that if render is out of CUDA memory it takes system RAM. But my scene has same error like in 2.79: Out of CUDA memory. Thanks in advice. And GREAT job. Realy thank you. UI rocks!!!
Brecht Van Lommel (brecht) triaged this task as Needs Information from User priority.Feb 12 2019, 11:33 AM
  • Please provide an example .blend file to reproduce the problem.
  • Please mention how much CPU memory your computer has, and how much memory each GPU has.
  • Does it happen when rendering with one of the GPUs, or only when using both?
We can only use a subset of CPU memory and that is itself limited as well of course, so there are still valid circumstances where it can run out of memory.
Brecht Van Lommel (brecht) closed this task as Archived.Mar 1 2019, 4:11 AM
Following bug tracker policy, closing report after 7 days due to insufficient information to investigate further. We can reopen the report if more information is provided.
