ExportHelper crashes with exit code 3221226356 when called
Operating system: Win 10
Broken: 2.80, ba6cf3cdb649, 2019-02-13, branch: blender2.7
Worked: Someone on Discord took the code, tested it in 2.79 and claims it works there.
When trying to call an "ExportHelper" in a "Props Dialog's" execute method, Blender crashes with the exit code "3221226356".
1.) Copy, paste and execute the provided code in Blender => A new "test" panel shows up in the 3D View.
2.) Click on "Props Dialog", then on the "OK" button within the pop up. This should open the file browser, but crashes Blender.
(The "File Browser" button in the panel invokes the same ExportHelper operator and works fine...)
import bpy
from bpy_extras.io_utils import ExportHelper
class Test_Panel(bpy.types.Panel):
    bl_space_type = "VIEW_3D"
    bl_region_type = "UI"
    bl_label = "Test"
    bl_category = "Test"
    @classmethod
    def poll(cls, context):
        return True
    def draw(self, context):
        layout = self.layout
        row = layout.row()
        row.operator('object.test_operator', text='Props Dialog')
        row = layout.row()
        row.operator('object.file_browser', text='File Browser')
class OBJECT_OT_Test(bpy.types.Operator):
    bl_idname = "object.test_operator"
    bl_label = "test operator"
    flt_prop:  bpy.props.FloatProperty(default = 0.25, min = 0, max = 1, name='')
        self.layout.column().prop(self, "flt_prop", expand=True)
    def invoke(self, context, event):
        bpy.context.window_manager.invoke_props_dialog(self)
        return {'RUNNING_MODAL'}
    def execute(self, context):
        bpy.ops.object.file_browser("INVOKE_DEFAULT")
        return {'FINISHED'}
class MENU_MT_FileBrowser(bpy.types.Operator, ExportHelper):
    bl_idname = "object.file_browser"
    bl_label = "test filebrowser"
    filename_ext= ".blend"
    filter_glob: bpy.props.StringProperty(default='*.blend', options={'HIDDEN'},)
    filepath: bpy.props.StringProperty(name="File Path", description="File path", maxlen= 1024)
        print("Did it!")
        return {'FINISHED'}
register, unregister = bpy.utils.register_classes_factory((OBJECT_OT_Test, MENU_MT_FileBrowser, Test_Panel))
if __name__ == "__main__":
    register()
Jacques Lucke (JacquesLucke) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 13 2019, 5:33 PM
I cannot reproduce this in the current build. Please check if the issue still exists.
If yes, then please start Blender from the terminal and post the output here.
G. Krause (G.Krause) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Feb 14 2019, 3:53 AM
G. Krause (G.Krause) updated the task description. (Show Details)
I have updated my Blender to yesterday's version and am unfortunately still having the same crashes.
I also updated my sample code in the first post, seems I deleted too much code when I was simplifying it. I am very sorry for that.
It should work (or rather crash) as intended now. I even added a small panel for convenience's sake.
The terminal shows:
The terminal process terminated with exit code: 3221226356
Terminal will be reused by tasks, press any key to close it.
(The latter, I guess, is because I use your VSC plugin, for which I humbly want to thank you a million times, as it stays open for a new Blender session?!)
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
I can confirm that there is something weird going on. If I open blender and paste in that script and run it and then use the Props Dialog, blender soft hangs for me as soon as I press the OK button.
However if I first open the file browser via the File Browser button, the Props Dialog works but segfaults if I press cancel in the file broswer menu.
