Blender 2.8: Shader node - Linking to Materiel Output/Volume causes a crash of Blender
Open, Needs Information from UserPublic
Operating system: Win10
Graphics card: AMD Vega64
Broken: d3870471edd7
Create a 3D bezier curve (object data: fill mode=full, depth=0.1). Switch 3D view to shade (LookDev) view. Create a material (add shader) for curve (Eevee). Add Volume Absorb or Emission. Link to Output - Volume. Crash!
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Tue, Feb 12, 5:18 PM
I can not reproduce this.
Does it still happen for you with the latest build? https://builder.blender.org/download/
Always provide the build hash and double check your date.
Could you try it for 3D curve? I add version of Blender to description. Thanks.
Still can't reproduce. Does the following file crash for you?
Thanks for the file. I tried to open the file and when I changed the radius of 3d curve (+enabled volume in eevee part) and deleted a link and made a new link and changed again radius - Blender crashed.
I tried those steps on my laptop and there is no crashes.
It seems to be a problem with my AMD Vega64 and Eevee/node shader. I tried to make debug and there is bad instance of Mesh structure in 3D Curve ( bad reference to vertices ).
There is a similary problem in other node shaders when I make many changes in value of some node (for ex. changing a value with mouse moving). Blender is very unstable in this way.
You can check if this is a driver issue by downloading this dll and copying it so its located in the same directory as 'blender.exe' and run Blender normally.
