screen area border not matching clickable area if thick lines is selected
Open, Needs Triage by DeveloperPublic
Operating system: Windows 7 64bit
Graphics card: GeForce 1060
Broken: blender-2.80.0-git.ec471a9b1c14-windows64 (built 16. Feb. '19)
in the preferences, switching "Line Width" from "Thin" to "Thick" makes
borders between screen areas wider by 4 pixels, but only 2 pixels wider
for the mouse cursor to grab it
  1. start blender, set "Line Width" to "Thin" in the preferences, if it is not already
  2. go to any screen area's border, notice that it is 3 pixels wide and you can grab it pixel-perfectly
  3. switch "Line Width" to "Thick"
  4. again look at any border, notice how it is 7 pixels wide but you can only grab the inner 5
not sure what to add, fixing this would obviously make it require less attention to resize areas
or for the right-click split/join operation.
cheers, boogie
I thought this “line width” was intended to only affect lines in the 3D editor? With it changing everything it makes it more complex to determine how big something is since this is independent of user scale. We currently have a very large number of unnoticed “off by a pixel” errors because of this.
For an example think about having to know the width of a some widget. Without line-width it is trivial to just work in ui_widget_units since these are changed with user scale. But adding line width makes the calculation complex since it depends on how many borders it has. You might have a user scale of 1.5 and thick lines or 2.0 and thin lines. Yikes.
