OpenEXR file with only R channel fails to read #61607
13 Participants
Reference: blender/blender#61607
Operating system: Linux Mint 19.1
Graphics card: GTX 1080ti / latest drivers
Broken: Current nightlies and own builds of 2.79 and 2.80
Worked: Official 2.79b and older nightlies (can't tell exactly when the problem started to occur, maybe 2 weeks?!)
If I render a simple multilayer EXR without a Z channel and load the resulting image file in e.g. Blender's image editor it looks black with an alpha although during rendering it looked OK.
Rendering with a Z channel gives the correct result.
It looks like Blender can't properly read its own layers any more.
Added subscriber: @SteffenD
#77574 was marked as duplicate of this issue
#63632 was marked as duplicate of this issue
Added subscriber: @AdamPreisler
Added subscriber: @BassamKurdali
I'm not sure if it's the same bug, but I've got an exr (a zbrush displacement map) that renders black in eevee, shows up black in the image / UV editors, but renders greyscale in cycles. It shouldn't have a Z pass, so maybe this is a similar bug. I'm attaching an exr and a test .blend (toggle between lookdev and rendered to see it in eevee/cycles)
zbrushdisp.blend
small addendum: I'm on gnu/linux (fedora 29), using intel cpu and nvidia gpu (i7/1080)
This issue was referenced by
eee46769ce
The JokerGargle_Displacement.exr is a different case than the original report. It has a single "R" channel. I'll keep the report open for that case.
Changed status from 'Resolved' to: 'Open'
Multilayer EXRs without Z channel give weird resultsto OpenEXR file with only R channel fails to readAdded subscriber: @brecht
Added subscriber: @iss
Still problem with JokerGargle_Displacement.exr
Added subscriber: @SeanKennedy
I've also run into this bug using the latest stable build of Blender 2.82a. Working on the workflow for STmap lens distortion/undistortion, the STmap I created in Nuke kept importing into Blender as completely black. When I added in a depth pass (not any real information, just a solid color value in the depth channel) and re-saved the EXR, it worked fine.
Including two EXR images, with and without zdepth channel, and a screenshot of both EXR images in Blender's compositor.
I created the same image in Natron instead of Nuke, and it worked fine. I did NOT include the z depth pass in this EXR. Otherwise, I used all the same image output settings that I used when rendering from Nuke.
Added subscriber: @irfancelik
Looks like it is naming related. The "..no_depth_pass.." exr shows up as Color.XY instead of Color.RGBA in Natron.
Added subscriber: @p2or
Added subscriber: @L0Lock
Added subscriber: @tutukivi
Added subscriber: @forcef
Someone please test Quixel .exr files, same issue seems to me and i cannot use roughness map because of that. Blender 2.83 Win 10 x64
Yup, any grayscale-type map downloaded as EXR from Quixel is unusable in Blender because it stores the data in a single R channel with no GBA channels.
I really hope 2.83.1 fixes that, i often want to preview scene/mesh/texture with PBR before moving target object to Unreal. I use .exr files directly in Blender without Bridge for quick preview but now it is not working because of this bug.
Anyone knows workaround for this? 2.83.1 still do not work. How to get that Z channel thing to work?
Added subscriber: @EAW
I am looking into fixing this issue. In the meantime You can work around the issue by opening the file in another program and add a G and B channel. The easiest way to do this that I have found is using GIMP.
.exr
The new file will now work in Blender.
Developers, any plan on fixing this for 2.90 at least or is it possible at all without compromising something?
5d88f8eba2
