Eevee - material gets darkened when shader is being mixed with itself using 'mix shader' #61704
Reference: blender/blender#61704
Windows 10, GTX 1080
Blender 2.80 2019-02-19 00:38
790cb7799d
See attached file. mix_shader_Eeevee_bug.blend
Shader is mixed with itself using 'mix shader' node. It's a simple mix so it should look the same whether it's 0 or 1. In Cycles it works correctly. In Eevee however it gets darkened.
Blender 2019.02.19 - 10.40.27.01.mp4
EDIT: I just noticed, that even when you mix two separate identical shaders there's still a difference in brightness. You can see that in the video in 00:25 on the lower right corner of the box, there's a slight variation in brightness. What is going is the second shader ignores Screen Space Reflections. If you turn SSR off they both look the same.
Added subscriber: @MarcinTwarowski
mix_shader_Eeevee_bug_simplified.blend
I just noticed, that even when you mix two separate identical shaders there's still a difference in brightness. You can see that in the video in 00:25 on the lower right corner of the box, there's a slight variation in brightness. EDIT: What is going is the second shader ignores Screen Space Reflections. If you turn SSR off they both look the same.
Added subscriber: @dfelinto
The issue is on the
ssr_data
calculated inbsdf_common_lib.glsl:closure_mix()
.Mainly it is mixing the ssr_data of closure 1 with (0,0,0,w) of closure2:
cl.ssr_data·=·mix(cl1.ssr_data.xyzw,·vec4(vec3(0.0),·cl1.ssr_data.w),·fac);·/*·do·not·blend·roughness·*/
Okay, talked to Clément and this is working by design. Although mixing RGB is fine, there is no way to reasonably mix SSR data.
So we are (by design) reducing the specular intensity when using the mix shader node in EEVEE.
I added some comments on
0e7409d466
explaining what is going on.I don't get it. I can mix base color maps, metallic maps, roughness maps and normal maps using mix RGB nodes and screen space reflection works just fine. Why is mixing shaders any different?
@MarcinTwarowski Because when you are mixing shaders you are mixing the result of the lighting calculation (and/or some other internal data for SSR). Sometimes these cannot be mixed because it would break the SSR completely.
This is the difference between mixing inputs of a bsdfs and the outputs.
To better see what I mean, compare mixing 2 glossy shaders with different roughness and just mixing their roughness instead. And when I say mixing, it is with intermediate values (like 0.5), not 1.0 or 0.0.
Yes, I was wrong. Mixing glossy shaders is not the same as mixing roughness. Thank you for clarification.
