Vertex Weight assigning to bone Issues in 2.8 #61719
Reference: blender/blender#61719
Comp: Alienware 17R4 i7 Core-7820HK CPU @ 2.90 GHz
Operating system: Windows 10
Graphics Card 1: RTX 2080 Ti 11GB
Graphics Card 2: GTX 1080 8GB
Blender: 2.80 beta
Broken:
790cb7799d
, 2/19/19Worked: ?
Weight assigning vertices to bone does not allow anything other than 0.0 or 1.0
i'm not sure why some meshes work and some do not, I saw this happen earlier with another armature, but i deleted it and started over and the problem was solved.
But i do not want to lose all my work, the whole mouth is rigged already.
Even if i set it to .01, it reacts as if i have full strength 1.0 assigned to the vertex.
this is a huge issue, and i need help with this. also if could be a bug.
Added subscriber: @Nathanyaahla
Added subscriber: @WilliamReynish
It seems as if you are using an addon here? Did you try and do this normally via the Properties or with Weight Paint mode, without the addon?
Actually, this is a feature in Blender 2.8 it’s not an add on that I’m aware of. But even so yes I just tested this with the weight options in the properties panel as well. Same results
This comment was removed by @Nathanyaahla
Added subscriber: @ZedDB
As this only happens with certain meshes, could you attach an example file where this is broken?
Added subscriber: @lichtwerk
