Crash when using EEVEE and ADM Radeon HD
Operating system:
Graphics card:
Broken:blender-2.80.0-git.790cb7799dcf-
When i try to enter in the texture or rendered mod of display it crashes.
Even when my scene is empty.
I open Blender,I press the button in order to switch the display mod and it crashes.
Jacques Lucke (JacquesLucke) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 20 2019, 2:17 PM
Which OS and GPU do you use?
Make sure that your GPU driver is up to date.
I have windows 10 and my GPU is ADM Radeon HD 7570M, i think, but the driver is up to date and it still crashes. Is my laptop so bad that it can't handle 2.8 ? because 2.79 works just fine.
Jacques Lucke (JacquesLucke) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Feb 20 2019, 8:10 PM
You could try to get a different daily build, and it might start to work. A factory reset might help, too.
Yeah, the OpenCL (AMD) Cycles code is in extreme flux the last day or two, so try another 2.80 beta download and see if there's any difference.
Brecht Van Lommel (brecht) renamed this task from A thing that i think it happens only to me to Crash when using EEVEE and ADM Radeon HD.Feb 21 2019, 11:53 AM
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 21 2019, 3:32 PM
Does it work if you download this dll and copy it so its located in the same directory as 'blender.exe' and run Blender normally?
Well, with that file added it doesn't crush anymore but its very slow.
That is because that .dll forces blender to use software rendering.
That means that the problem is with your GPU drivers and not blender.
You can try if updating drivers help any: https://www.amd.com/en/support/graphics/amd-radeon-hd/amd-radeon-hd-7000m-series/amd-radeon-hd-7570m
But as you can see, your card has been end of life for quite a while now.
Yeah, you are right. I will stick to the 2.79 until i get a better computer.
Tanks anyway.
Sebastian Parborg (zeddb) claimed this task.
