Missing "Select With" and "Select All Toggles" shortcuts
Closed, InvalidPublic
Operating system: Windows 8.1 64 bit
Graphics card: EVGA GTX 970
Broken:
(2.80, 1af810b4ff17, blender2.8, 2019-02-20, as found on the splash screen)
Hi Blender devs, I would ask for someone to please bring back the extremely handy "Select With" and "Select All Toggles" shortcuts as shown in the Blender 2.8 screenshot below. These are the 2 most important shortcuts for users to transition to 2.8 and they are unfortunately missing from the latest build. It takes between 5 - 10 minutes to change all these settings manually, so having these simple shortcuts would be super helpful and should probably be located in the "Input" menu beside the "Mouse" settings.
Thanks so much, and congrats on a brilliant new Blender... really really nice work!
Sincerely,
Adam Janz
William Reynish (billreynish) closed this task as Invalid.
These only appear when using the built-in keymap. If you use custom keys we cannot display this. You can reset to the built-in keymap to see it again.
Ah, I see. That's unfortunate... but thanks so much for letting me know about that... I discovered a workaround that gives me the best of both worlds. :-) Switch back to the Blender default config, activate your settings from that menu, then save a custom preset. If you need to make any changes (such as turning on extra shading options in the pie menu), switch back to the Blender default config, change the settings, then save a new (or overwrite) a custom preset. Works perfectly... thanks so much William!!!! This really made my day. :-)
