FBX Exporter: vertices exported in incorrect position causing mesh deformation
Confirmed, NormalPublicBUG
Operating system: Windows 10 x64
Graphics card: RTX 2070
Broken: 2.79, 2.8
When skinned meshes are exported with FBX 7.4 binary the position of vertices does not export correctly.
As a result meshes are deformed (visible but not extreme in most cases) after export.
Note that external tools/software may be required to compare the meshes as the bug may be invisible upon re-import to blender.
A good way to see the differences is to use the mesh wireframe in iso view in blender versus unity for example.
Comparison of before and after in sample case (Click to load gif)
  1. Load the attached blend file.
  1. Export to FBX using 7.4 binary
  2. Compare the position of vertices before and after export.
Related Objects
Tsuna Hiiragi (Tsuna) updated the task description. (Show Details)
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Mar 7 2019, 12:58 PM
I can't reproduce this on re-import into blender.
If blender imports the generated file, that means that at least to blender, the positions does not change.
There is not much we can do with simply "it doesn't import correctly in other program".
Tsuna Hiiragi (Tsuna) added a comment.EditedMar 9 2019, 9:35 PM
It may be difficult to see in blender on its own but this is a significant issue as you can not trust blenders export.
This means that the model is deformed in unity, unreal etc when it has been exported from blender (and only from blender).
It's a big deal when any kind of precision is needed.
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 90.Mar 11 2019, 11:47 AM
@Bastien Montagne (mont29) can you reproduce this?
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Mar 12 2019, 10:25 AM
No, cannot reproduce, but I don’t have access to Unity or UE currently.
Re-importing into Blender works as expected, so geometry itself is definitively not altered, issue likely comes from the rigging (binding matrices and all that). Although I would still find it odd that this shows in some other app but not in Blender. FBX works in mysterious ways… :(
Tsuna Hiiragi (Tsuna) added a comment.EditedAug 6 2019, 2:52 PM
{F7651610}So I found a semi viable workaround which is to set pose to rest position until the issue was small enough. This can take anywhere between 1 to 30 attempts. However due to some changes in 2.8 this is not possible anymore.
The mesh always exports in the exact same state. However the incorrect positioning of the verts is more major in 2.8
See attached a testcase for 2.8
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Feb 15 2020, 3:14 AM
I have re-triaged this report and can not reproduce it.
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
@Richard Antalik (ISS) Tested with 2.83 Alpha .
Able to reproduce the issue.
For safety i also tried entering pose mode and applying pose to rest.
Same result as previously.
Verified in 3dsMax 2020, Unity 2019.2.4 and Unity 2017.4.28<
The incorrect deformation is identical in all 3 instances.
Richard Antalik (ISS) changed the task status from Needs Information from User to Confirmed.Feb 18 2020, 9:38 AM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
