Blender crashes when creating new file using shortcut Cntrl N
Open, Needs Information from UserPublic
Operating system: Windows 10 pro
Graphics card: AMR Radeon
Broken: Blender 2.8 779860d34e26
(example: 2.79b release)
Blender occasionally crashes when executing Cntrl N > General (Specially when a file is open). I have attached a video to show you the issue. The problem seems to happen only when the command is executed through the shortcut (Cntrl N). I tried several blend files (besides the ones shown in the video) and got the same result.
I couldn't reproduce it in the video, but Blender has crashed even when the scene is empty or has just a few basic objects.
Thank you,
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.
That shortcut doesn't seem to be in either the default keymap or the 2.7 keymap in 2.8. Could you provide the exact keybinding command?
Hello,
All what I do is hit (Cntrl N) in the 3D viewport window. I have always used that shortcut since 2.79 and even before.
Thank you,
I can't seem to reproduce the crashes on my side. I'm guessing this is still a problem for you with the latest build?
Yeah, it still crashes. I literally tested it with the latest experimental version of Blender 2.8 (At the time when I wrote this message). version: 490a385c8124. :( It happens regardless of the file that I am working on so there is no point on sending a specific blend file. It is also worth mentioning that Blender doesn't crash when I execute the command from the top menu bar: File>New>General. Blender only crashes when using the shortcut Ctrl N.
Does it still crash if you force blender to use software rendering? Download this dll and copy it so its located in the same directory as 'blender.exe' and run Blender normally.
wow it didn't work and it also made the viewport super slow. I could barely rotate the 3d viewport.
Yes, I tested the shortcut and Blender crashed again. My CPU is intel core i7-2600K @ 3.40GHz. Just in case.
Sebastian Parborg (zeddb) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Mar 4 2019, 10:14 AM
This may be due to the initialization of some unofficial addons.
@Jorge Molina (georgbernier), if that is the case, could you try again but with the Blender's factory settings restored?
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Tue, Jun 11, 11:18 AM
