Documentation for building Blender with Xcode doesn't work #61902
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#61902
Downloaded the latest code from master, and followed the tutorial here https://wiki.blender.org/wiki/Building_Blender/Mac.
Got it working by modifying CMake to include "WITH_BOOST". I would like to update the tutorial but I cannot find any place to edit it, and the IRC seem to be abandon.
Added subscriber: @mgchris
What exactly you'd like to edit? Did you first run make update under source tree before cmake/cmake gui?
Added subscriber: @brecht
It should not be necessary to manually set
WITH_BOOST
in any case, that would indicate a bug in the build system that needs to be fixed.I wasn't able to repro this. Building with XCode worked for me.
@mgchris what steps did you do?
@ArtoKitula I used CMake GUI (3.14.0-rc2).
Steps:
Configure
and waited for it to finishGenerate
and waited for it to finishinstall
Scheme (Note it might be better to sayPress Command+shift+,
instead ofCommand-<
)Automatically Create Schemes
. (Maybe update the docs saying to select that option?)Executable
toblender.app
Undefined symbols for architecture x86_64:
for a bunch of boost methods.If I repeat the process except I select
WITH_BOOST
before step 3, everything builds and runs correctly.Added subscriber: @Blendify
This discussion belongs on https://devtalk.blender.org/c/blender/building-blender
