Visible wireframe artifacts after baking normal map with bevel shader
Operating system: Windows 10 Pro
Graphics card: MSI GTX 1080Ti
Broken: blender-2.80-779860d34e26 and since the bevel shader implementation
Bevel shader when baked to the normal map has slight discolorations that follow mesh wireframe. Color shifts from 8080ff to 807fff in those areas and crates unwanted artifacts.
Bake a normal map of your low poly mesh with bevel added in your material. It's most visible on flat areas with some triangles.
https://youtu.be/24qJbVURDQY
Jacques Lucke (JacquesLucke) triaged this task as Needs Information from User priority.
I don't know a lot about baking in Blender, however it looks like the issue here is already on the original mesh.
Adding new edges like so might fix the issue:
Or use custom normals somehow...
Can you solve the issue with that information?
Jacques Lucke (JacquesLucke) claimed this task.
