File with missing 3D view region data crashes #61929
5 Participants
Reference: blender/blender#61929
Blender 2.8 / 24 and 25 Feb 2019
How to reproduce:
Select cube, M to move Cube to Collection 2, Ctrl Z to undo = crash.
New/other files are ok.
It is not depend of collections or an object (I made new and crash still there)
Here the file with a problem nomov.blend
Added subscriber: @Vyach
I can reproduce the crash.
Not sure if we can fix this, if we can't reproduce it in a new file.
Can you remember how you created this file?
The same way, as others, from custom startup file , that I made from default startup ((it is ok)) .
I can share both: startup and item. There is nothing valuable. IDK if it'll help.
The only uncommon detail during work with this file: I pressed Ctrl+Z, and hit the limit of Undo. Then I changed limit of global undo to 64.
Then work some more, tried to move duplicates into another collection with wrong selection, like this:
Finally found, what is wrong (no sync selection from 3dview to outliner), moved duplicates, Ctrl+Z, Crash.
Then worked some more, and think, if i can reproduce crash or it was sudden.
startup file 28.blend
кинжал 1.blend
Added subscriber: @ZedDB
@Vyach can you still reproduce the crash in the first file if you disable "Load UI" when you open it?
First file have no such bug at all. It is initial file for comparation with bugged.
But with the second one without UI-loading project start to work fine, no crashes.
Added subscriber: @brecht
I can't seem to reproduce this from scratch.
@brecht any ideas?
Backtrace:
Did you found the difference between startup file and nomov.blend? May be that difference can lead to the root of bug…
This issue was referenced by
e5194835de
Bugged file: Move to collection — Undo — Crashto File with missing 3D view region data crashesChanged status from 'Open' to: 'Resolved'
