Redrawing an UIList on Property Dialog crashes Blender 2.8x
Open, Confirmed, MediumPublic
Operating system: Windows 7
Graphics card: GTX 970
Broken: 2.80, 6bab905c9d40, blender2.8, 2019-02-24
Worked: 2.7x
Redrawing an UIList on a Property Dialog crashes Blender 2.8x
Following simple example creates a dialog that allows to display previously selected images from disk via UIList using a PropertyGroup to store them.
  1. Run the script to test call Image List operator
  2. Press Add Files to List
  3. Select an arbitrary Image
The code runs without any issues in 2.7x. However in 2.8, after selecting an image from disk (coming back from the File Browser) Blender crashes because of supplying row.template_list(...) within the draw method. When removing that line the dialog comes back as expected, but without the list of course :). I'm not sure what the issue is. I even don't get any valuable error when running blender in debug mode, just crashes instantly.
For debugging I also added the same UIList to the Toolbar of the Text Editor, which works as expected.
2.8x (Broken)
import bpy
from bpy.props import IntProperty, CollectionProperty, StringProperty
from bpy.types import Operator, Panel, UIList
from bpy_extras.io_utils import ImportHelper
import os
#   Operators
class ImageSelectOperator(Operator, ImportHelper):
    """Select Images within the File Browser"""
    bl_idname = "custom.image_select"
    bl_label = "Select Image(s)"
    bl_options = {'PRESET'}
    filter_glob: StringProperty(
            default="*.exr;*.tiff;*.jpeg;*.jpg;*.pic;*.png",
            options={'HIDDEN'},
    files: CollectionProperty(type=bpy.types.PropertyGroup)
    def execute(self, context):
        scn = context.scene
        folder = (os.path.dirname(self.filepath))
        # Iterate through the selected files
        for i in self.files:
            path_to_file = (os.path.join(folder, i.name))
            item = scn.custom.add()
            item.id = len(scn.custom)
            item.name = i.name
            item.path = path_to_file
        self.report({'INFO'}, "Files added to the List")
        # Call the file browser
        bpy.ops.custom.popup_dialog('INVOKE_DEFAULT')
        return {'FINISHED'}
class UIListActions(Operator):
    bl_idname = "custom.list_action"
    bl_label = "List Action"
    action: bpy.props.EnumProperty(
        items=(
            ('REMOVE', "Remove", ""),
            ('ADD', "Add", "")
    def invoke(self, context, event):
        scn = context.scene
        idx = scn.custom_index
        try:
            item = scn.custom[idx]
        except IndexError:
            pass
        else:
            if self.action == 'REMOVE':
                info = 'Item %s removed from list' % (scn.custom[scn.custom_index].name)
                scn.custom_index -= 1
                if scn.custom_index < 0: scn.custom_index = 0
                self.report({'INFO'}, info)
                scn.custom.remove(idx)
        if self.action == 'ADD':
            bpy.ops.custom.image_select('INVOKE_DEFAULT')
            scn.custom_index = (len(scn.custom))
        return {"FINISHED"}
#   Drawing
class ULItems(UIList):
    def draw_item(self, context, layout, data, item, icon, active_data, active_propname, index):
        split = layout.split(factor=0.7)
        split.prop(item, "name", text="", emboss=False, translate=False, icon='IMAGE')
        split.label(text="Index: %d" % (index))
        pass
class PopupDialog(Operator):
    """Displays the Popup Dialog"""
    bl_idname = "custom.popup_dialog"
    bl_label = "Image List"
    bl_options = {'REGISTER'}
        return {'FINISHED'}
        return context.window_manager.invoke_props_dialog(self, width=400)
    def check(self, context):
        return True
    def draw(self, context):
        layout = self.layout
        scn = bpy.context.scene
        try:
            current_item = (scn.custom[scn.custom_index].name)
        except IndexError:
            current_item = ""
        row = layout.row()
        Crashes Blender 2.8x
        row.template_list("ULItems", "", scn, "custom", scn, "custom_index", rows=2)
        row = layout.row()
        col = layout.column(align=True)
        rowsub = col.row(align=True)
        rowsub.operator("custom.list_action", icon='ZOOM_IN', text="Add Files to List").action = 'ADD'
        rowsub.operator("custom.list_action", icon='ZOOM_OUT', text="Remove File").action = 'REMOVE'
        row = layout.row(align=True)
        row.label(text="Active Item is: {}".format(current_item))
# DEBUGGING
class UIListPanelExample(Panel):
    """Creates a Panel in the Text Editor"""
    bl_idname = 'OBJECT_PT_my_panel'
    bl_space_type = "TEXT_EDITOR"
    bl_region_type = "UI"
    bl_label = "Custom Image Files"
        try:
        except IndexError:
            current_item = ""
        row = layout.row()
        row = layout.row()
class CustomProps(bpy.types.PropertyGroup):
    #name: StringProperty() -> Initiated by default
    path: StringProperty()
#   Register & Unregister
classes = (
    CustomProps,
    UIListActions,
    ImageSelectOperator,
    ULItems,
    UIListPanelExample, # DEBUGGING
    PopupDialog
def register():
    from bpy.utils import register_class
    for cls in classes:
        register_class(cls)
    bpy.types.Scene.custom = CollectionProperty(type=CustomProps)
    bpy.types.Scene.custom_index = IntProperty()
def unregister():
    from bpy.utils import unregister_class
    for cls in reversed(classes):
        unregister_class(cls)
    del bpy.types.Scene.custom
    del bpy.types.Scene.custom_index
if __name__ == "__main__":
    register()
2.7x (Working)
import bpy
import os
#   Operators
    filter_glob = StringProperty(
            options={'HIDDEN'},
    files = CollectionProperty(type=bpy.types.PropertyGroup)
        scn = context.scene
            item.name = i.name
        return {'FINISHED'}
    action = bpy.props.EnumProperty(
        items=(
            ('ADD', "Add", "")
        scn = context.scene
        try:
        except IndexError:
            pass
        else:
        return {"FINISHED"}
#   Drawing
        split = layout.split(percentage=0.7)
        split.prop(item, "name", text="", emboss=False, translate=False, icon='IMAGE_COL')
        pass
        return {'FINISHED'}
        return True
        try:
        except IndexError:
            current_item = ""
        row = layout.row()
        row = layout.row()
# DEBUGGING
        try:
        except IndexError:
            current_item = ""
        row = layout.row()
        row = layout.row()
    id = IntProperty()
    path = StringProperty()
classes = (
    CustomProps,
    UIListActions,
    ULItems,
    PopupDialog
def register():
    for cls in classes:
        register_class(cls)
def unregister():
    register()
Cheers,
Christian
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.
I can reproduce it. Can you try to remove everything from that script that is not necessary to reproduce the bug? That would make debugging a bit easier.
Hey @Jacques Lucke (JacquesLucke),
of course. Just wasn't sure what's easier to debug. I tried to strip it down as best as I could:
import bpy
from bpy.props import CollectionProperty, IntProperty
import os
#   Operators
class FileSelectOperator(Operator, ImportHelper):
    bl_idname = "custom.file_select"
    bl_label = "Select File"
        scn = context.scene
        fpath, fname = os.path.split(self.filepath)
        item.name = fname
        self.report({'INFO'}, "{} added to the List".format(fname))
        return {'FINISHED'}
#   UI List
class UIListActionAdd(Operator):
        scn = context.scene
        return {"FINISHED"}
        layout.row().prop(item, "name", text="", emboss=False, translate=False, icon='IMAGE')
        return {'FINISHED'}
        return True
        scn = context.scene
        self.layout.row().template_list("ULItems", "", scn, "custom", scn, "custom_index", rows=2)
        self.layout.row().operator(FileSelectOperator.bl_idname, icon='ZOOM_IN', text="Add Files to List")
    #name: StringProperty() -> instantiated by default
classes = (
    FileSelectOperator,
    UIListActionAdd,
    ULItems,
    PopupDialog,
    CustomProps
def register():
    for cls in classes:
        register_class(cls)
def unregister():
    register()
    # test call
I Hope that's better. Just let me know if I can do anything else.
Cheers,
Christian
CTX_wm_region(C) returns NULL in uiTemplateList(..) directly after the file selector is closed.
When I skip the function in this case, everything goes back to normal on the next redraw.
@Campbell Barton (campbellbarton), I'm not sure at which level this has to be fixed...
