Blender 2.8 subsurface modifier bug. #62008
Reference: blender/blender#62008
Operating system: Windows 10
Graphics card: MSI GTX 1060
2.80 Beta
Subsurface Modifier 2.8 behaved differently compare to 2.7 version
Create a cube,
add Subsurface Mod level 1.
Go to edit mode.
The edge of the mesh doesn't stick to the bounding box.
Link for example with video and image.
https://blender.stackexchange.com/questions/132951/blender-2-8-subfsurf-modifier-behave-different-compare-to-2-7
Added subscriber: @harun
Added subscribers: @Sergey, @ZedDB
The issue here is that the new subdiv code uses the limit surface (the surface of the cube is you subdivide it an infinite amount of times) to place the verts.
IIRC there is already a toggle to enable/disable this in the code.
@Sergey I guess we could add an option in the modifier to toggle this on and off?
I can do it if you want to.
@ZedDB, i would not consider difference in behavior a bug, and would not expose that option. The drawbacks are much more serious than one might think:
What we currently use is called "adaptive refinment", which basically means topology refiner will stop analyzing mesh once its reached certain threshold of how close patch is to the limit surface. For a regular character like meshes this is really only few levels deep.
The alternative is called "uniform refinment", and that will keep creating patches which approximate the surface for until the very last level. This is because you can't approximate those with a b-spline surface, and effectively ending up creating patches for every high-res face.
I see. Thanks for the explanation. Then I don't think there is much to do here in this regard either.
