Please help me!
Operating system: N/A
Graphics card: N/A
Broken: i believe it was the windows 84 bit version. if you click on other versions its the first on to say windows.
(example: 2.79b release)un
Worked: nope
it won't open it says that the program is broken or something. it says "c:\Program Files\Blender Foundation\Blender\OpenAL32.dll is either not designed to run on windows or it contains an error. try installing the program using the original installation media or contact your system administrator or the software vendor for support. error status 0x0000022" don't know what to do.
Based on the default startup or an attached .blend file (as simple as possible). i just opened it.
LazyDodo (LazyDodo) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 27 2019, 7:58 PM
please try a nightly build from builder.blender.org
excuse me... but what? did you even read it? it doesn't even open. it just says, that with a black screen behind it. sorry if that sounds aggressive. but what info is needed? i stated the problem and what it did and what always happens. i haven't gotten Blender to even open yet.
go to http://builder.blender.org and download the latest build available, to see if the issue is still there
i did
That's why i'm suggesting trying a later build.
Apology not accepted, there is no reason to be this agitated with people trying to help you
And i gave you a possible solution and all you did is lash out at me ignoring my advise.
but what info is needed? i stated the problem and what it did and what always happens....
I think the information needed is the exact version of Blender that you are using. And you are
being asked if it does the same thing if you download a newer version from:
https://builder.blender.org/download/
again i am very sorry. I've been trying for the past three weeks and have made no progress. I've tried different versions. i'm very sorry, i know you were trying to help and i thank you for that. i shouldn't have lashed out at people just trying to help after i asked for help. thanks for the ideas, I hope they work! i have added the version i used, i hope that helps for info
newest non beta version is downloading now! fingers crossed!
This might be an error with your operating system and not blender. Searching "Bad Image Error" brings up a lot of results related to Windows. Some solutions might be to Restore to a previous point in time. Sorry, but this is the best advice I can give right now..
Please fill in your operating system details. Without this information it is difficult to help you.
darn. it didn't work. but i got closer then ever before!
yeah i don't think it'll ever work on this computer. it's a school one and it's really crappy and slow. i'll try again on my home computer, thanks for all the help! all of you!
Bad image is generally when you're trying to run the 64 bit version of blender on 32 bit windows. if you grabbed the 64 bit version of blender, give the 32 bit version a try.
OpenAL32 is something related to audio.
Check the sound card drivers. Try disable sound card.
Jacques Lucke (JacquesLucke) claimed this task.
