Wirefame , random crash #62030
5 Participants
Reference: blender/blender#62030
Operating system: Windows 10
Graphics card: Radeon HD 7600m
Broken:
blender-2.80-b1c3d91aed42-win64
Worked:
before the wireframe color builds
set Wireframe , istant crash.
it does not happen with the default scene with only the cube,
with that I was not able to crash blender by setting the wireframe.
Loading scenes a little bit more complex like mr_helepant, or other, set the wireframe mode and you get instant crash.
This does not always happen,
sometimes do not crash
it's random but the crash happens frequently, and always the same way, selecting wireframe mode
system-info.txt
Added subscriber: @nokipaike
Added subscriber: @capnm
I don't have any issues here. This was probably fixed, check with the latest build.
Added subscriber: @ZedDB
Can't reproduce this either. If it doesn't get solved with a later beta build, you could try and see if it crashes with software rendering to see if this might be a driver issue.
Download this dll and copy it so its located in the same directory as 'blender.exe' and run Blender normally.
Added subscribers: @fclem, @mano-wii
ok guys,
I have tested the same files with the internal gpu intel HD 4000
I can confirm that by starting blender with the same files, I do not have any crashes ... so I suspect there is some mess with the usual buggy amd Radeon HD Drivers for the pre-gcn obsolete gpu
@fclem @mano-wii
@mano-wii I just tested the last build blender-2.80-
490a385c81
-win64unfortunately your fix
fa5950d878
may have improved the situation for some things, but the problem has not been solved, the scenes continue to crash as beforeI'll give you this blend file so check yourself
wasp_bo_ottimizzato8.blend
just press the wireframe button with the mouse and instantly crash.
if you open blender and set the wireframe mode, and load one of these scenes (having disabled "loadUI" from the file), blender crash just loads the file.
this particular problem has emerged since the color wireframe was inserted, so I think it's something related to this.
edit:
I suspect it is something that remains in the memory of the GPU even after the crash
with this file I passed you, doing nothing but opening it:
first 2 loop
third loop
double click again to start with the file
fourth and fifth loops
crash at first time as the first two loops
fifth time
you have to go wireframe - solid six times before it crash ...
more or les this loops of crash are cyclic.
edit2:
I made a video, which shows that the situation has not changed even for objects based on curves and surfaces .. maybe it takes a lot more because the crash happens, but it happens ..
after an addition of subdivisions blender crash
moreover, but maybe this does not mean anything, I noticed that at each select-click, for a certain number of clicks the memory increases ..
(I also tested the thing with a factory default to prevent it being some addon, and blender behaves the same way)
https://youtu.be/3kUHCSyO5WY
Removed subscriber: @capnm
Added subscriber: @ideasman42
I was able to reproduce the crash. I'll investigate;
On the increase in memory, it should be related to the UNDO system. But I'm not sure.
Maybe @ideasman42 knows what that is.
also with the attempt to fix
ae977d13f8
the situation has remained unchanged, blender continues to crash with the wireframe mode ...it seems that the more you have wireframes in the buffer, the more chance you have of a crash
@mano-wii
I have done other digging work:
on all heavy scenes like mr_elephant, wasp_bot, wanderer, all crashing scenes, if I select all objects and enter edit mode, there is no way to crash blender, switching from wireframe mode to solid mode ...
then I did, always with all the selected objects, a remove doubles ... and also a "make normal consistent"
and I discovered this:
wasp_bot scenes no longer crash, there is no way to make it crash.
mr_elephant is more stable but sametimes crash
wanderer I do not know if it's improved but it keeps crashing ..
the two scenes, wanderer and mr_elephant have problems of normal flipped in some points ...
I also discovered maybe another bug on wanderer:
selecting all the objects, entering edit mode, selecting all, selecting all the points, but pressing "deselect all", some objects remain with their selected points, and there is no way to deselect them, even by pressing several times select all and deselect all
and I found out that multicolor in edit mode (by selecting all objects) is not working ... and that's probably what does not make blender crash in wireframe in edit mode ... because I just get out of edit mode blender crash
@mano-wii Nice Strike man!
not only is blender now as solid as a rock ...
but in heavy scenes, now the gpu feels that it works more (the fan will turn faster to cool)
soo...there's more:
trust me, I do these tests every day, I know what I'm talking about ...
I made a video ...
https://youtu.be/OMuuKst532k
I would say problem solved obviously ..
The change in the GPU work should not be significant.
It's possible, but it's probably not related.
However I realize that there are some areas to optimize.
Certainly these areas will be considered in future tasks.
the shaders now take a bit more to take shape the first time I set the scene in EEVEE mode, and even to load they put a pinch more ... I always talk about those heavy scenes ...
And I also noticed that the "vbo cache" now "saturates faster" ... and so if I make a switch between solid and eevee mode sometimes blender recalculate the shaders like the first time ...
the gpu no doubt works more intensely ... remember when I told you that "the fan worked at low rpm" while I was coloring that scene with the mechanic and the robots? ...
@nokipaike I commited
798d2cadc3
which might be related to the perf improvement you got but i'm not certain. I also doubt @mano-wii 's commit made any different. But whatever, the result is here.I also noticed something that is making me really very very happy ...
that once the "vbo" has recalculated ... the gui starts to become light and responsive ...
(I always speak in heavy scenes with eevee activated)
the opposite is that "this buffer on the gui" is downloaded and recalculated every time I set a new color or parameter in general ...
it is a pity that do so ...
but surely it is much better than before ..
and with some polish work ... you could get great results here.
@fclem I had not noticed this change you made today..
yes .. it could be also for this
